Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to correctly use and maintain your food processor
Ce dont vous avez besoin
    • Place the processor base permanently on the countertop to encourage frequent use.
    • Verify the bowl, lid and blade are securely locked before starting the motor.
    • Always unplug the processor before fitting, removing or cleaning any attachment.
    • An intact safety interlock pin on the lid is required for the motor to run.
    Demander à FixBot
    Ajouter un commentaire
    • Load up to 500 g of flour and other dry ingredients into the bowl, then add liquids on top.
    • Drop dry yeast directly on the flour; blooming is unnecessary thanks to rapid mixing.
    • Lock the lid and choose the highest speed so the motor works at full torque.
    • Listen as the pitch smooths; when the blade no longer slaps, hydration is complete.
    • A clean blade and bowl wall indicate perfectly kneaded dough ready for proofing.
    • Overloading beyond the capacity listed in your manual can strain the gearbox.
    • For larger machines rated for 800 – 1000 g of flour, follow the manufacturer’s limit.
    Demander à FixBot
    • Weigh the eggs, using the built-in or external scale.
    • Add flour equal to double the egg weight, plus a pinch of salt and a few drops of oil.
    • Engage the processor; high speed yields small particles, medium speed makes larger ones.
    • Dough pellets form within seconds; add a splash of water and run slower for bigger farfel.
    Demander à FixBot
    • Start the motor with the S-blade empty to create the air vortex.
    • Drop small pieces of onion, garlic, carrot or herbs through the feed tube onto the spinning blade.
    • The circulating air keeps produce dry, preventing onion juice and bitterness when sautéed.
    • Scrape bowl walls with a spatula and pulse again for a finer mince.
    Demander à FixBot
    • Load the full batch of vegetables into the bowl, fit lid and engage lock.
    • Pulse in short bursts until the desired size is reached.
    • Adding a boiled potato and a ladle of hot water then pulsing produces a quick blended soup.
    Demander à FixBot
    • Install the adapter and a full metal disc; teeth facing up for shredding, knife edge up for slicing.
    • Feed produce while applying only the pressure needed for movement.
    • More pressure yields thicker slices; gentle pressure produces very thin cuts.
    • Roll cabbage leaves into a tight log before feeding for uniform shreds.
    • Watch the bowl level; if produce piles too high the disc lifts and can scar the lid.
    • Feed carrots vertically for short sticks or horizontally for long strips.
    Demander à FixBot
    • Place apples peel side up to trap the skin on the lid, or peel side down to include it in the shreds.
    • Feed zucchini or cucumber gently, adjusting pressure to set slice thickness.
    Demander à FixBot
    • Guide the cheese so it barely touches the disc, allowing light contact only.
    • Excessive pressure overworks the motor and can crack the drive system.
    • When the last piece is nearly through, release the pushrod and stop the motor.
    Demander à FixBot
    • Load fully frozen chicken breast into the feed tube.
    • Apply gentle, steady pressure; the disc shaves the meat into coarse mince.
    • The result cooks like ground meat, handy when you lack a dedicated grinder.
    Demander à FixBot
    • Combine nuts with a spoonful of breadcrumbs or sugar to absorb released oil.
    • Pulse until the grind suits your recipe.
    • Stop before the mixture turns pasty to avoid overloading the motor.
    Demander à FixBot
    • Slightly freeze the meat and trim sinews to prevent strands from wrapping the blade.
    • Pulse in short bursts; an even ball forming around the blade means uniform mincing.
    Demander à FixBot
    • Chill 0.5 % milk in the freezer for about an hour so ice crystals form.
    • Process with the S-blade or whisk until thick foam appears.
    • Add citrus juice or mashed banana for flavor and body while the foam is fresh.
    • The foam liquefies over time because of low fat, so enjoy immediately.
    Demander à FixBot
    • Load frozen berries, sliced banana, a few mint leaves and your preferred sweetener into the bowl.
    • Run at high speed, pausing to scrape down the sides until creamy.
    • Serve the soft ice cream straight from the bowl.
    Demander à FixBot
    • Verify your processor uses a single-piece blade and a sturdy polycarbonate bowl.
    • Add up to 500 g of normal-sized frozen strawberries and lock the lid.
    • Hold the base firmly and run at maximum speed until the rattling stops.
    • Fold in banana or cream, scrape the walls and blend again for uniform texture.
    • Do not attempt with oversized fruit pieces or weak plastic bowls.
    Demander à FixBot
    • Wash blades, discs and bowl by hand when possible; occasional dishwasher cycles are acceptable.
    • Hand washing preserves sharp edges and prevents plastic clouding.
    • Treat the lid’s safety pin gently; a drop can snap it and spares may be hard to source.
    • Wipe the motor block with a damp cloth only; never submerge.
    • Clear air vents regularly to prevent motor overheating.
    • Always unplug the processor before any cleaning or part removal.
    Demander à FixBot
With these techniques and maintenance habits your food processor can knead, chop, shred, grind and whip for decades while staying sharp, safe and reliable.
Ula Gantar
Membre depuis le 01/08/25
16 609 Réputation
81 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 39
Total : 146
