Introduction
This guide will tell you how to prevent somebody to steel your money and/or identity when your credit or debit card expired or is replaced.
Note this can NOT be undone
Take a magnet and swipe it over the magnetic strip minimum 10 times.
  • Take a magnet and swipe it over the magnetic strip minimum 10 times.
  • Take something sharp and make hole where the chip was.
Ajouter un commentaire
Use a pair of scissors and cut the card into thin strips.
  • Use a pair of scissors and cut the card into thin strips.
  • See the photo.
  • It is not recommended to have the strips thicker then 2mm.
Saving and collecting the little gold emblem could make you some money in the future.
Clifton Linne - Réponse
  • The distance you see in the blue circle is not recommended to be more then 2mm.
  • Cut the card into many small parts as seen on the photo.
  • It is recommended to have a box/tin to prevent the parts to fly anywhere.
  • Look on the floor and on the table and see if you lost some parts of the card
  • If you found some, cut them also.
  • See previous steps.
  • Take some parts in the trash at home and some other an other place, eg work, public area, etc.
  • Recomanded min 2 places
    • Taking it to the neighbor will not increase security a lot.
Ligne d'arrivée
23 autre(s) ont terminé cette réparation.
Truls Zhong Konstali
Membre depuis le 09/05/2014
1 279 Réputation
1 tutoriel rédigé
You didn't mention how to destroy the chip. You need to destroy the chip also. Otherwise this method is very good (excellent if it wasn't a chip card.)
thealy449 - Réponse
Would've been easier to burnt the CC to ashes . Now that's one and only one way that you will keep it from falling in to the anyone's scam, fraud...
Hiram Pabon - Réponse
Please correct some typo but yes you got the
Now for anything that has 2 do w/a/pc's smartphone has a has a has a.
Rabitts take the hard drive and burnt it to a crispy ashes.
Fire destroyed anything
Destroys anything
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 33
30 derniers jours : 207
Total : 8,274
