Introduction
The disassembly of this water kettle can be done by anyone with the help of this manual and the required tools. At one point, you might need and extra pair of hands, so make sure that someone is available when needed.
Ce dont vous avez besoin
This is the Bodum Bistro Water kettle, with a capacity of 1.5 L . We are going to disassemble this.
After this, locate the three, already visible screws and unscrew two of the three screws with a PH2 and the other one with a PH 1 screwdriver.
Next, you can detach the black plastic part with the switch after loosening the red wires from the plastic. With this, you can remove the plastic tube as well.
Om het apparaat weer te monteren, volg je deze instructies in omgekeerde volgorde.
