Introduction
In this guide, I will explain how to fix a loose microphone arm on a Logitech G432 headset. One of the most common issues of this headset is the microphone arm being loose, and fixing it can be quite tricky.
In this guide, you will learn what parts to take out of the headset and how to properly take those parts out with the end goal being able to reach the microphone arm screw and adjust how tight it is. However, we want to be as cautious as possible when taking apart the headphones ,as its wires and cables are quite short and sensitive.
Ce dont vous avez besoin
Remove the ear pads by gently lifting them from the headset. They are easy to take off, so no need to be rough.
Remove the sticker, and it is recommended to use a small tool that can peel the sticker off from underneath.
After removing the sticker, you can Remove the fourth and final screw, which is similar to the other three screws. Then open the headset cautiously, as the wires inside are short and sensitive.
