Aller au contenu principal
How to fix a blown heater element in a Toaster
Ce dont vous avez besoin
Vidéo d'introduction
    • Insert wisdom here.
    • how to fix a toaster
Not too difficult, you need patience though.
4 autres ont terminé cette réparation.
jon
Membre depuis le 05/15/16
2 949 Réputation
22 tutoriels rédigés
2 commentaires
this solution worked great for a bout a two weeks, then despite having connectivity in the ribbon, it does not heat up. It sounded like you weren’t expecting your solution to work forever. Did it give out on you after a little bit because of the increased resistance and the crimp?
mitchell.drury - Réponse
Mine is still working even after all this time (over 2 years ago). If your heater element is still connected (low resistance) then the fault is somewhere else. Trace the resistance of connections back through the switch to the plug to find the fault.
jon - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 35
30 derniers jours : 119
Total : 24,940
