Aller au contenu principal
How to fix a door that won't latch
Ce dont vous avez besoin
  1. How to fix a door that won't latch, How to fix a door that won't latch: étape 1, image 1 de 2 How to fix a door that won't latch, How to fix a door that won't latch: étape 1, image 2 de 2
    • Identify the door that is having trouble closing.
    • The cause of the problem in this instance is the towel hanger preventing the door from fully latching. However, this fix will help any causes of a door not having sufficient clearance to latch.
  2. How to fix a door that won't latch: étape 2, image 1 de 3 How to fix a door that won't latch: étape 2, image 2 de 3 How to fix a door that won't latch: étape 2, image 3 de 3
    • Using a Phillips #2 screwdriver, loosen and remove the two screws holding the striker plate in place.
    • Remove the striker plate.
  3. How to fix a door that won't latch: étape 3, image 1 de 2 How to fix a door that won't latch: étape 3, image 2 de 2
    • Once the striker plate has been removed, the area where the door latch fits into the door frame (known as the mortise) needs to be enlarged.
    • Using the wood chisel, scrape away small parts of the door frame to create enough space for the door to latch.
    • Scrape away from the flat side of the mortise, or the edge that would stop the door from moving to an open position.
    • You don't want to remove more wood than necessary, so try closing the door periodically to see if there's enough room for the latch to engage.
    • After there's enough room for the door to click shut, make a few more light passes with the chisel, since the striker plate (once it's installed) will occupy some of the space of the mortise.
    • Wood chisels are very sharp. When using the chisel to enlarge the mortise, be sure to position the chisel so that if it slips it won't injure you or anybody working with you.
    • If your chisel is dull, you might find it difficult to remove the wood from the door frame. Tapping the back of the chisel gently with a hammer can help make this easier.
  4. How to fix a door that won't latch: étape 4, image 1 de 3 How to fix a door that won't latch: étape 4, image 2 de 3 How to fix a door that won't latch: étape 4, image 3 de 3
    • Now line the strike plate up so that the the hole is lined up with the expanded mortise and draw a dot inside the two screw holes to mark where you'll be drilling.
    • Using a drill bit slightly smaller than the outer diameter of the screw, drill new screw holes in the door frame.
    • Most door frames are made out of soft pine, which means that the new holes will be very easy to drill. This also means that the surface tends to splinter when you first start drilling the new hole, which can make the new hole look ugly. Don't worry though - this will get covered by the striker plate once it's installed.
  5. How to fix a door that won't latch: étape 5, image 1 de 3 How to fix a door that won't latch: étape 5, image 2 de 3 How to fix a door that won't latch: étape 5, image 3 de 3
    • Finally, reattach the strike plate using the newly made holes.
  6. How to fix a door that won't latch: étape 6, image 1 de 2 How to fix a door that won't latch: étape 6, image 2 de 2
    • Once the striker plate has been reinstalled, shut the door and verify that it latches properly.
    • Once the fix has been verified and the door shuts properly, clean up the wood shavings on the floor.
Once the fix has been verified and the door shuts correctly, you’re all set! Over time this problem might pop up again if the door hinges continue to sag, and if that continues to happen then the only correct solution is to rehang the door. Failure to do this will eventually lead to a door that scrapes across the floor when it is opened or closed.
Benjamin Morris
Membre depuis le 01/30/20
163 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 19
30 derniers jours : 55
Total : 4,448
