Introduction
This is an advanced repair, requiring specialized skills and equipment. This video does not include disassembly or reassembly steps.
In this tutorial you will learn how to resolve the matter with the boot problem in an iPhone 7 [stuck on the apple logo]. In case of troubles just ask!
15 autres ont terminé cette réparation.
19 commentaires
Was the circuit changed? or was it done reballing?
Thanks for your interest :) Chip replacement with reballing.
thank you so much
What is the name of this compononte?
Where do I meet for purchase?
You need to get it from the another motherboard.
It is called the reflow, you need to restore the proper connection between the chip and the motherboard.
Hi, so was you heat the specific components or you have replaced it with another one components from another logic board.
No, recalling involves heating up the solder just to the point where it melts. Once the solder cools back down It makes a better connection than before, therefor it is called “recalling” and not replacement.
I have an iPhone 7. before 6 months I put on the update whereas putting on the charger and went for the work. when I return home my phone was off . then I tried to on the phone then the notification was connected to iTunes. then I connected to 3u tools and did iTunes flash that was failed because of error code 10 . can you please find the solution for this issue?
Hello,
my Iphone 7 storage was full, and when opening any app it close directly and any try to delete data to make some had failed so I tried to shutdown the phone, when I tried to power it up again it stuck on apple logo, so i connected the phone to itunes and tried to update it, in the middle of the process itunes gave me unknown error 14, and then the phone stuck on recovery mode.
any idea to fix the problem without losing any data? would this method fix the issue? and would some applications like dr. fone fix it without any data loss?
(battery health is 76%)
thank you in advance.
the downloaded software is IOS 13
leo -
what if my home button doesn’t work while my phone is stuck on apple logo?
hi..what is this IC name? it is in which ciruit?
