Aller au contenu principal
How to Fix Jammed Nintendo Switch ZR and ZL buttons
Ce dont vous avez besoin
  1. How to Fix Jammed Nintendo Switch ZR and ZL buttons, Unscrew the back cover: étape 1, image 1 de 1
    • Using the Y00 Tri-Point screwdriver, remove four M1.4 x 5mm screws to loosen the hard plastic back of the Joy-Con.
    • After the screws are removed, lift the cover to reveal the inside of the Joy-Con and locate the ZL button.
    • The button exposed could either be the ZL or the ZR depending on which Joy-Con needs to be fixed.
    • Use tweezers to lift the ZL button a little then pull upwards to get it back into place.
    • Once the button is back in place, place the hard cover back on the Joy-Con and screw it back on.
    • Click the button a couple times to ensure that it's back in place and working.
    • This may either be the ZL or ZR button depending on the Joy-Con being fixed.
  2. How to Fix Jammed Nintendo Switch ZR and ZL buttons: étape 5, image 1 de 1
    • Resume gameplay!
After following those 7 steps, your gameplay should return to its original state. If the other Joy-Con also has a jammed ZL or ZR button simply repeat the 7 steps above.
12 autres ont terminé cette réparation.
Gabriela Cruz-Pagan
Membre depuis le 02/02/20
435 Réputation
1 tutoriel rédigé
Équipe
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 Membre de l'équipe USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020
USFSM-STEWART-S20S1G1
23 membres
27 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 41
7 derniers jours : 342
30 derniers jours : 1,634
Total : 91,681
