Introduction
Utilisez cette méthode pour forcer le démarrage d'un OnePlus Nord si la communication s'interrompt, les menus se bloquent, ou bien si l'appareil est bloqué.
Appuyez simultanément et maintenez le bouton d’augmentation du volume et le bouton de mise en marche.
Relâcher les 2 boutons quand le logo OnePlus apparait.
19 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
9 commentaires
what is this weird problem one plus nord suddenly get switch off while on call ..
kindly advice to get ride of this problem for forever .
My mobile has hanging & automatically switch off/on please solve problem
It worked! Great help! Thank youuu
Finally after trying for over 2 hours! Than you so much!
mi telefono aparese que est corrupt i lo e reiniciado pero no enciende nomas cae eso
Ok now mine is stuck on the start and recovery menu but I can't select start bc my power button doesn't work
Thank you so much for this.
my 1 plus nord touch screen not working...i already have restart it many times with press power and long press volume ..now neither its swiching off nor working...please help me to atleast switching it off
Finally - THAT worked!! Thanks. Other fixes from other sites tell you to press the “power off button”. Duh! Screen not responsive! Kudos for your research and answers.
freerealm - Réponse
As you suggested i did it . Finally i got my mobile started.
Epic Hemang - Réponse
I find charging port is too loose and does not connect with charging cord.. Battery charge runs out. What should I do?
amicuscurious - Réponse
Most of the time its because there is dust in the charging port that causes that. Gently try to clean that and it should be good as new.
Sparky -
