Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears
Ce dont vous avez besoin
    1. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears, Back Panel: étape 1, image 1 de 1
      • Turn the device over so that the base is facing up.
      Demander à FixBot
      Ajouter un commentaire
    2. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: étape 2, image 1 de 1
      • Peel off the piece of metal that is glued to hold the two halves of the base together.
      • You may need to reapply glue to the piece of metal when reassembling the device.
      Demander à FixBot
    3. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: étape 3, image 1 de 2 How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: étape 3, image 2 de 2
      • Unscrew the four 10mm Phillips head screws on the bottom of the device.
      • Once the base is removed, the device should look as shown on the picture.
      Demander à FixBot
    1. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears, Motor: étape 4, image 1 de 2 How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears, Motor: étape 4, image 2 de 2
      Outil utilisé dans cette étape :
      • Use a pair of tweezers to crush the sides of the wirenuts.
      • The wirenuts are crimped to lock the wires in place. Usually the wires are just twisted into them.
      • Pull all of the wires out of the wirenuts.
      Demander à FixBot
    2. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: étape 5, image 1 de 2 How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: étape 5, image 2 de 2
      • Separate the wires that belong to the motor.
      • The wires should be small and black.
      • Remove the motor.
      Demander à FixBot
    1. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears, How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: étape 6, image 1 de 1
      • Remove the two 10 mm Phillips #1 screws.
      • Remove the center 14 mm Phillips #1 screw.
      • Remove the plastic piece stabilizing the gear.
      Demander à FixBot
    2. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: étape 7, image 1 de 1
      • Gently apply oil to the gear using a Q-tip.
      Demander à FixBot
Nick Kaprielian
Membre depuis le 01/14/14
531 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 17-3, Forte Winter 2014 Membre de l'équipe Cal Poly, Team 17-3, Forte Winter 2014
CPSU-FORTE-W14S17G3
5 membres
84 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 25
30 derniers jours : 64
Total : 1,693
