Introduction
Most repairs require the espresso machine to be opened. This is shown here. Please note that there are models with a decorative frame made of metal and others made of plastic (shown here).
These instructions may also help with other Saeco models and with coffee makers from Philips and Gaggia—they are all made by the same manufacturer and have a very similar design.
Ce dont vous avez besoin
First check which model you have in front of you: Is the decorative frame made of chromed metal (picture 1) or of metallized plastic? (picture 2). In the first case follow this guide, in the second case you are in the right place here.
Lay the machine on its side. Now you can lift off the side panel. There is a small notch in the top right and it is probably still a bit stuck.
In principle, the side with the service flap could also be removed in a similar way, but this is not necessary for many repairs.
Picture 2 shows the Moltio with side panel open:
pump
flowmeter
PCB
heater
8 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
2 commentaires
Super Bilderklärung mit den farbigen Hinweisen.
So und nicht anders ist es richtig erklärt.
