Introduction
This guide shows how to remove the motherboard from the Nokia Lumia 928.
Outils
Pièces
Aucune pièce spécifiée.
Start by powering off the phone.
Next remove the sim card tray.
Once sim tray is removed you can now remove the T5 screw from the sim card slot.
Now insert the T5 screwdriver into the headphone jack. There is a T5 screw in the headphone jack that has to be loosened.
First free all ribbon cables from their connections on the motherboard.
The two areas circled in red are where the ribbon cables connections need to be freed from the logic board.
Free the ribbon cables from the logic board with a plastic pry tool.
Now that the ribbon cable connections are free you will now need to remove a metal clip around the usb port.
Now we can begin by removing the 10 T5 screws from the motherboard.
With all ten T5 screws removed we can now lift from the left side of the motherboard. that needs freed
The area in yellow is the only connection on the underside of the motherboard that needs to be freed up. This is the display connection.
Pry the connection loose from the motherboard with a plastic pry tool.
Now you can remove the motherboard.
6 autres ont terminé cette réparation.
