Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to repair a buckle (ski braces)
Ce dont vous avez besoin
  1. How to repair a buckle (ski braces), Identify the defect: étape 1, image 1 de 3 How to repair a buckle (ski braces), Identify the defect: étape 1, image 2 de 3 How to repair a buckle (ski braces), Identify the defect: étape 1, image 3 de 3
    • Locate the part of buckle that needs fixing.
    • Note: if your buckle has actually broken or snapped, use a "seam ripper" tool, or small pair of scissors to carefully cut the threads holding the seam together. Then remove the defective buckle and obtain a replacement.
  2. How to repair a buckle (ski braces), Clean the area: étape 2, image 1 de 3 How to repair a buckle (ski braces), Clean the area: étape 2, image 2 de 3 How to repair a buckle (ski braces), Clean the area: étape 2, image 3 de 3
    • Use a seam ripper and scissors to cut off the damaged thread.
  3. How to repair a buckle (ski braces), Reinsert the buckle: étape 3, image 1 de 3 How to repair a buckle (ski braces), Reinsert the buckle: étape 3, image 2 de 3 How to repair a buckle (ski braces), Reinsert the buckle: étape 3, image 3 de 3
    • Insert the buckle in the fabric loop.
    • Check that the position is correct, and that the other half of the buckle will clip on correctly.
    • Note: It is easy to sew the clip in back-to-front - so one extra check before stitching is worthwhile!
  4. How to repair a buckle (ski braces), Stitching: étape 4, image 1 de 3 How to repair a buckle (ski braces), Stitching: étape 4, image 2 de 3 How to repair a buckle (ski braces), Stitching: étape 4, image 3 de 3
    • Fix the buckle in place and use the sewing machine to make a straight stitch from one end to the other.
    • Repeat the process 1-2 times for extra durability; and add a lock stitch on both ends.
  5. How to repair a buckle (ski braces), Finished and ready!: étape 5, image 1 de 1
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
Membre depuis le 07/19/23
10 230 Réputation
68 tutoriels rédigés
Équipe
INTERSPORT Membre de l'équipe INTERSPORT
Community
25 membres
171 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 15
30 derniers jours : 36
Total : 477
