Introduction
When practicing your sport in summer or winter, it's easy to get a tear in your T-shirt, leggings or jacket. Knitted fabrics are very stretchy and the best way to repair a hole is to sew it by hand, as explained in this guide.
Ce dont vous avez besoin
Lay the woven textile on a flat surface with the tear fully exposed.
Check how large the tear is, where it is on the item, and whether it is fraying at the edges.
Consider: this repair will be visible at the end, so you might wish to use a matching thread colour - or - you might want to celebrate this memory with some contrast colour thread! Think about how you want the final repair to look before starting.
Prepare the needle with the thread.
Turn the defective product inside-out, and pinch the broken edges together, so that they are facing towards you.
Pass the needle through both pieces of fabric, starting at one end of the hole. Tie a knot to secure it, and pull gently. Be careful not to bunch the fabric, especially if it is lightweight and thin.
Continue sewing along the hole with a regular sewing technique; passing the needle through both pieces of fabric from one side, then from next side, and so on.
Work your way along the seam until the entire hole is closed. Before Making a knot, check whether you think the repair is strong enough - if not, repeat the sewing procces back along the hole to the starting point.
Make a knot at the end of the repair.
Make a final test of the repair by lightly stretching the area.
Trim off the excess thread
🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Inspect the repair and trim any excess thread. Turn the textile inside out to check the stitching on the reverse side. Trim any loose threads and ensure a clean and tidy finish.
