Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to repair the power switch and wire contact in your juicer
Ce dont vous avez besoin
    • Pull the mains plug out of the socket before opening the appliance.
    • Place the juicer on a stable table with good lighting and gather your tools.
    Demander à FixBot
    Ajouter un commentaire
    • Press the power switch to confirm it is jammed or stuck.
    • A blocked switch usually feels seized and does not click in or out.
    Demander à FixBot
    • Remove all visible Phillips screws from the base of the juicer.
    • Lift each rubber foot to reveal hidden screws and remove them too.
    • Keep the screws in a tray so you do not mix lengths.
    Demander à FixBot
    • Unclip the plastic latches holding the housing together.
    • Lift the upper shell carefully to avoid stretching internal wires.
    Demander à FixBot
    • Remove the single Phillips screw securing the switch mechanism to the housing.
    • Lift the module out while noting its orientation and cable routing.
    Demander à FixBot
    • Wipe away sugar residue and old grease from the cross-shaped rotor and spring.
    • Apply a small amount of fresh grease to the sliding surfaces.
    • Handle plastic parts gently to avoid breaking thin tabs.
    Demander à FixBot
    • Fit the small torsion spring back onto its post and hook it into the rotor.
    • Apply a tiny drop of cyanoacrylate and activator to keep the spring from falling off.
    • Use minimal glue; excess can lock the mechanism.
    Demander à FixBot
    • Manually press the switch to ensure it now clicks and releases smoothly.
    • If movement is still stiff, repeat cleaning and alignment.
    Demander à FixBot
    • Align the housing halves and snap the clips back together.
    • Reinsert all screws, including those under the feet, and tighten them evenly.
    Demander à FixBot
    • Plug the juicer in and verify the motor starts and stops with the switch.
    • Unplug again before moving to additional work.
    Demander à FixBot
    • Remove the six Phillips screws from the underside of the second juicer.
    • Lift the cover to expose the motor, wiring and micro-switches.
    Demander à FixBot
    • Unclip the strain relief to free the mains cable from the housing.
    • Disconnect the spade terminal from the micro-switch and photograph wire positions.
    • Cut off the cracked or broken terminal from the wire.
    Demander à FixBot
    • Strip a few millimetres of insulation to reveal clean copper strands.
    • Slip the original insulation sleeve onto the wire for later use.
    Demander à FixBot
    • Set the soldering iron to 350–400 °C.
    • Apply flux to the exposed strands and coat them with a thin layer of solder.
    Demander à FixBot
    • Apply flux to the new spade terminal and pre-tin the contact area.
    • Clean and tin the iron tip regularly on a damp sponge or scouring pad.
    Demander à FixBot
    • Place the tinned wire into the tinned terminal and heat until solder flows together.
    • Let the joint cool without movement to avoid cold solder joints.
    Demander à FixBot
    • Crimp the insulation grip on the terminal around the wire jacket.
    • Crimp the conductor grip firmly around the soldered strands.
    Demander à FixBot
    • Slide the original sleeving back over the joint to insulate the connection.
    Demander à FixBot
    • Reconnect the repaired terminal to the micro-switch.
    • Secure the cable in the strain relief and route wires as found.
    • Close the housing and reinstall all screws.
    Demander à FixBot
    • Plug in the juicer and verify that the motor starts when safety interlocks are engaged.
    • If the juicer operates correctly, the repair is complete.
    Demander à FixBot
A sticky switch or broken wire contact can take only minutes to fix and saves the whole juicer from the scrap heap. Treat the plastic housings gently, keep your solder joints neat, and always unplug before any work. Enjoy many more glasses of fresh juice from your freshly repaired appliance.
Ula Gantar
Membre depuis le 01/08/25
16 609 Réputation
81 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 17
30 derniers jours : 64
Total : 321
