Aller au contenu principal
How to replace a Euro Cylinder in a Mortise Lock
Ce dont vous avez besoin
  1. How to replace a Euro Cylinder in a Mortise Lock, Measure the cylinder: étape 1, image 1 de 1
    • Open the door.
    • Measure the distance from the the forend screw holding the cylinder to the faceplate as shown in the picture.
    • Buy the new cylinder.
    • The maximum overhead you can dimension the new cylinder too large is 2mm. If The cylinder sticks out too much it becomes vulnerable to cracking.
  2. How to replace a Euro Cylinder in a Mortise Lock, Remove the screw: étape 2, image 1 de 1
    • Use a PZ2 screwdriver to remove the fixing screw from the side of the lock.
    • Some older locks might use a slotted screw instead.
  3. How to replace a Euro Cylinder in a Mortise Lock, Remove the cylinder: étape 3, image 1 de 3 How to replace a Euro Cylinder in a Mortise Lock, Remove the cylinder: étape 3, image 2 de 3 How to replace a Euro Cylinder in a Mortise Lock, Remove the cylinder: étape 3, image 3 de 3
    • Insert the key and turn it to about 20° to the right (or left) to release the cylinder from the lock insert.
    • If you don’t have the old key or the cylinder doesn’t work anymore you can give this guide a try.
    • Pull out the old cylinder.
To install the new cylinder, follow these instructions in reverse order.
Sebastian
Membre depuis le 08/19/18
21 643 Réputation
60 tutoriels rédigés
Équipe
German Translators Membre de l'équipe German Translators
Community
29 membres
768 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 23
Total : 287
