Aller au contenu principal
How to replace a broken back cover on a Sony Xperia Z3
Ce dont vous avez besoin
  1. How to replace a broken back cover on a Sony Xperia Z3, The Phone.: étape 1, image 1 de 1
    • The cover we are going to replace.
  2. How to replace a broken back cover on a Sony Xperia Z3, Heating.: étape 2, image 1 de 2 How to replace a broken back cover on a Sony Xperia Z3, Heating.: étape 2, image 2 de 2
    • Start by using a blow-dryer on the hottest setting. Heat the entire backside of the phone, and focus on the edges for a minute or two.
  3. How to replace a broken back cover on a Sony Xperia Z3, Loosening the cover.: étape 3, image 1 de 3 How to replace a broken back cover on a Sony Xperia Z3, Loosening the cover.: étape 3, image 2 de 3 How to replace a broken back cover on a Sony Xperia Z3, Loosening the cover.: étape 3, image 3 de 3
    • Use a suction-cup to pull up the back-cover about 1mm. Insert a pick and use a second one to make the opening larger.
  4. How to replace a broken back cover on a Sony Xperia Z3, Removing the cover.: étape 4, image 1 de 3 How to replace a broken back cover on a Sony Xperia Z3, Removing the cover.: étape 4, image 2 de 3 How to replace a broken back cover on a Sony Xperia Z3, Removing the cover.: étape 4, image 3 de 3
    • Use the picks to get the cover off as far as possible. After this, wear gloves and try to pull off the glass. It will break in this step, so be careful for any pieces of sharp glass!
  5. How to replace a broken back cover on a Sony Xperia Z3, Removing glass.: étape 5, image 1 de 2 How to replace a broken back cover on a Sony Xperia Z3, Removing glass.: étape 5, image 2 de 2
    • Continue removing the looser pieces. Use plastic tools, so you don't damage the electronics inside.
  6. How to replace a broken back cover on a Sony Xperia Z3, Removing the main piece: étape 6, image 1 de 3 How to replace a broken back cover on a Sony Xperia Z3, Removing the main piece: étape 6, image 2 de 3 How to replace a broken back cover on a Sony Xperia Z3, Removing the main piece: étape 6, image 3 de 3
    • Use the black tabs to pull the white double-sided tape. Remember not to pull these up, but stretch them to the sides. Pull carefully to avoid snapping.
  7. How to replace a broken back cover on a Sony Xperia Z3, More glass.: étape 7, image 1 de 3 How to replace a broken back cover on a Sony Xperia Z3, More glass.: étape 7, image 2 de 3 How to replace a broken back cover on a Sony Xperia Z3, More glass.: étape 7, image 3 de 3
    • You can now take off the glass that was attached to the battery.
    • Carefully remove all the glass and tape that's left.
    • Clean out all the glass with a small soft brush. I used the tip of an soft toothbrush.
  8. How to replace a broken back cover on a Sony Xperia Z3, NFC sticker.: étape 8, image 1 de 3 How to replace a broken back cover on a Sony Xperia Z3, NFC sticker.: étape 8, image 2 de 3 How to replace a broken back cover on a Sony Xperia Z3, NFC sticker.: étape 8, image 3 de 3
    • Be sure to clean all the glass! Use tape to carefully pick up the small pieces.
    • We still need to remove the NFC sticker to place in the new cover.
    • Carefully peel it off the old cover.
  9. How to replace a broken back cover on a Sony Xperia Z3, Placing the NFC sticker.: étape 9, image 1 de 3 How to replace a broken back cover on a Sony Xperia Z3, Placing the NFC sticker.: étape 9, image 2 de 3 How to replace a broken back cover on a Sony Xperia Z3, Placing the NFC sticker.: étape 9, image 3 de 3
    • Place the NFC sticker in the free space in the tape on the inside of the new cover.
    • Press it down.
    • The contact sensitive area on the sticker will line up with the connectors on the motherboard.
  10. How to replace a broken back cover on a Sony Xperia Z3, The new cover.: étape 10, image 1 de 3 How to replace a broken back cover on a Sony Xperia Z3, The new cover.: étape 10, image 2 de 3 How to replace a broken back cover on a Sony Xperia Z3, The new cover.: étape 10, image 3 de 3
    • This is our new cover. Why not a new color? Not too expensive on eBay. This is an aftermarket version.
    • Peel off the protective plastic.
  11. How to replace a broken back cover on a Sony Xperia Z3, Placing the new cover.: étape 11, image 1 de 2 How to replace a broken back cover on a Sony Xperia Z3, Placing the new cover.: étape 11, image 2 de 2
    • Line the cover up with one of the corners and align it along the long edge.
    • Before you drop it in, you can make small adjustment to line it up with the opposite corner.
    • Gently press it down along all edges and about two thirds down, where the cover sticks to the battery.
  12. How to replace a broken back cover on a Sony Xperia Z3, Finishing touches.: étape 12, image 1 de 2 How to replace a broken back cover on a Sony Xperia Z3, Finishing touches.: étape 12, image 2 de 2
    • Wipe all smudges off the back with a microfiber cloth.
    • Give it one last press along the edges while wiping.
    • And we're done. A nice new gold back cover for an Xperia Z3.
    • If you want you can protect the glass with a tempered screen-protector. Keep in mind that this may influence your case choice.
The phone is normally waterproof, and should still be, after this repair. However, I have not tested it, so I can not give a conclusive answer on how water-proof the device stays after repair.
48 autres ont terminé cette réparation.
larsjj
Membre depuis le 09/11/15
1 549 Réputation
1 tutoriel rédigé
11 commentaires
My european Sony Xperia Z3 had much more glue attached to the battery, making it much harder to remove all of the glas.
Max A - Réponse
Worked anyhow :-) Looks awesome again!
Thanks for the guide!
Max A -
My new back just won't stay stuck down. Can ib use super glue on it? I think half the battle is the phone heating up and loosening the glue.
Ben Clayton - Réponse
I'd be careful using superglue. Some sticky kit might be better. Maybe heating up the new one and holding it down with clamps or a book should make it stick better too.
larsjj -
Hi, I replace The back cover this morning and everything work well but when I attached the new back cover power button stopped working :(.. Do you have any suggestion what I should do? If I plug it into the USB it started charging and screen work but I cannot get it to power on..
Nezha - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 38
Total : 44,532
