Introduction
If the motor runs but the blade stays still, the drive belt is probably broken, stretched, or has slipped off its pulleys. Replacing or retensioning the belt and adding fresh lubrication to the motor bushing and gearbox restores full power and protects the gears from wear. Perform this repair whenever you notice slipping, squealing, or dry running noises.
Ce dont vous avez besoin
Étape 1 Disconnect power and clear the work area
Remove the bowl, blades, and any other accessories.
Étape 2 Expose the cover screws
Insert a flat screwdriver under a rubber foot on the base.
Lever the foot out to reveal the hidden screw below.
Repeat for every foot that hides a screw hole.
Étape 3 Remove the bottom cover
Unscrew all exposed screws and set them aside safely.
Lift the bottom cover off the housing to access the drive area.
Étape 4 Inspect the original belt
Check whether the belt is torn, overstretched, or merely slipped off a pulley.
Étape 5 Select a matching replacement belt
Take the old belt to a shop that specializes in belts to obtain an identical replacement.
Match the new belt by overall length, tooth pitch, and tooth thickness.
Étape 6 Loosen the motor mount for tension adjustment
Locate the four screws that secure the motor to its mounting plate.
Loosen each screw just enough for the motor to slide on its slots.
Étape 7 Lubricate the motor bushing
Add a few drops of machine oil to the lower motor shaft bushing.
Étape 8 Install the belt and set correct tension
Loop the belt over the large drive pulley first.
Slip the belt onto the motor pulley.
Pull the motor away until the belt deflects about 3 to 5 mm under firm thumb pressure.
Hold the motor in position and tighten two opposite mount screws.
Re-check belt flex, then tighten the remaining mount screws fully.
Étape 9 Reassemble the base
Place the bottom cover back onto the housing.
Insert and tighten all cover screws securely.
Étape 10 Test basic operation
Reconnect power and run the motor briefly with no load to verify smooth, quiet operation.
Confirm that the belt stays centred on the pulleys without walking off.
Étape 11 Open the gearbox cover on gear-drive models
Remove the single screw securing the upper gearbox cover.
Undo the three small screws that hold the gearbox plate in place.
Étape 12 Grease the gearbox bushing and gears
Lift the gearbox plate along with its bushing and washers.
Spread industrial grease on the metal bushing and plastic gear teeth while rotating the gear by hand.
Apply grease to the shaft and the bushing inside the cover.
Étape 13 Reassemble the gearbox
Return the washers to their original order on the shaft.
Seat the gearbox plate and insert all three screws finger-tight.
Tighten the screws in an alternating pattern so the plate sits evenly.
Re-fit the outer cover and secure its screw.
A correctly tensioned belt and fresh lubrication can bring even decades-old food processors back to full performance. Repeat lubrication and belt checks whenever the machine starts to slip or sound dry to keep it working like the first day.
