Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to replace the heating element in your air fryer
Ce dont vous avez besoin
    • Unplug the air fryer from the electrical outlet before starting.
    Demander à FixBot
    Ajouter un commentaire
    • Remove the three screws on the underside of the lid and lift away the metal plate.
    Demander à FixBot
    • Hold the fan firmly and loosen the central nut with an 8 mm wrench.
    • Slide the fan off the shaft and watch the thin metal blades, they are razor sharp.
    • Take off the small spacer hidden behind the fan and store it safely.
    Demander à FixBot
    • Undo the three internal screws to release the heater housing panel.
    • Work slowly because there is very little room inside the lid.
    Demander à FixBot
    • Remove the two main screws and the third stabilising screw that secure the heating element.
    • Straighten the side metal bracket so the element can move freely.
    Demander à FixBot
    • Mark the red, black and earth wires with a marker or a photo before disconnecting them.
    • Pull the connectors off the thermostat and heater terminals using needle-nose pliers.
    Demander à FixBot
    • Lift the heating element out of the lid once the wires and screws are free.
    • Avoid the unfinished glass rim; it is sharp enough to cause cuts.
    Demander à FixBot
    • Choose a halogen or coil element with the same power rating, about 1300 W, as printed on the old part.
    • Position the new element, tighten its mounting screws and close the side bracket.
    • Reconnect the labelled wires, refit the housing panel, spacer, fan and nut, then reinstall the metal plate.
    • The lid is fully rebuilt by following the disassembly steps in reverse order.
    Demander à FixBot
Your air fryer should now heat up normally again. If the unit still fails to reach temperature, verify every connector is firmly seated and confirm the replacement element matches the original wattage.
Ula Gantar
Membre depuis le 01/08/25
16 609 Réputation
81 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 78
30 derniers jours : 348
Total : 3,023
