Aller au contenu principal
How to replace the main PCB
Ce dont vous avez besoin
  1. How to replace the main PCB, Remove the screws: étape 1, image 1 de 1
    • Unscrew the four screws of the metal plate underneath the Warthog.
  2. How to replace the main PCB, Remove internal screws and cables: étape 2, image 1 de 2 How to replace the main PCB, Remove internal screws and cables: étape 2, image 2 de 2
    • Carefully remove the four screws displayed on the picture.
    • Disconnect the two cables displayed on the picture by making sure to not damage them. A pair of flat pliers might be recommended.
  3. How to replace the main PCB, Unsolder the PCB: étape 3, image 1 de 1
    • Using a soldering iron, remove the previous PCB and replace it with the new one.
    • Once that is done, reassemble the product.
  4. How to replace the main PCB, Update the firmware : open the updater: étape 4, image 1 de 2 How to replace the main PCB, Update the firmware : open the updater: étape 4, image 2 de 2
    • You will then need to update the firmware of the new PCB. To do that, connect the Magnetic Base (with a joystick on it) to your computer.
    • (First picture) If you have not already, download and install the driver of the product available on Thrustmaster support : https://support.thrustmaster.com/en/prod...
    • (Second picture) Open the "Firmware Updater". To do that, write "Firmware Updater" in the Windows search bar, the open the software.
  5. How to replace the main PCB, Update the firmware: étape 5, image 1 de 3 How to replace the main PCB, Update the firmware: étape 5, image 2 de 3 How to replace the main PCB, Update the firmware: étape 5, image 3 de 3
    • (First picture) Your device appears in the firmware updater. Apply the update by clicking on "OK".
    • (Second picture) The update is in progress.
    • (Third picture) The update is done ! You can close the firmware updater by clicking on the arrow at the top right corner.
  6. How to replace the main PCB, Calibration - Getting the software: étape 6, image 1 de 3 How to replace the main PCB, Calibration - Getting the software: étape 6, image 2 de 3 How to replace the main PCB, Calibration - Getting the software: étape 6, image 3 de 3
    • (Picture 1) Finally, you need to recalibrate the device. Thrustmaster has made this tool available here: https://nextcloud.guillemot.fr/index.php...
    • (Picture 2) Extract the archived file on your computer.
    • (Picture 3) Launch the calibration software.
  7. How to replace the main PCB, Calibration: étape 7, image 1 de 1
    • The calibration software will detail all the steps to follow. Make sure your Warthog Stick is connected to your computer, with a compatible joystick mounted on it.
    • Once you have fully followed all the steps of the calibration tool, you are done !
SarahK
Membre depuis le 08/16/24
145 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 35
Total : 267
