Introduction
If your microwave suddenly stops working, the main fuse may have opened to protect the appliance. Replacing this inexpensive component can restore normal operation without a full service call. Follow this guide only if you feel confident with basic hand tools, and never attempt other microwave repairs because the internal high-voltage circuitry can be lethal.
Ce dont vous avez besoin
Étape 1 Observe safety precautions and disconnect power
Unplug the microwave from the mains outlet before you begin any work.
Étape 2 Remove the outer cabinet
Remove every screw that secures the metal cabinet to the chassis, checking all sides and the rear for fasteners.
Lift the cabinet straight back and off to expose the internal components while avoiding contact with them.
Étape 3 Locate the main fuse
Find the cylindrical fuse mounted in a clip near the top or side of the chassis, often next to a board marking labelled “FUSE”.
Étape 4 Verify the fuse rating
Read the voltage and current values on the removed fuse or on the board; typical ratings are 250 V and 8 A.
Étape 5 Test the original fuse
Inspect glass fuses for a broken filament or dark burn marks as an initial check.
Set a multimeter to continuity or beep mode and place the probes on each end of the fuse.
Étape 6 Install the new fuse
Grip the replacement fuse with insulated pliers and align it with the spring clips.
Étape 7 Reassemble the microwave
Reposition the metal cabinet and reinstall every screw removed earlier, tightening them securely.
With the cabinet securely reinstalled, plug the microwave back in and test its operation. If the new fuse opens immediately or the unit still fails to run, discontinue use and contact a qualified service technician for further diagnosis.
