Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Just a few steps, and the Tchibo Cafissimo is set back.
    • Open the big metallic lever and switch of the machine
    • Press the espresso button (the top of the 3 coffee buttons) and while holding switch on the machine. Release the button. (If it's not working, repeat this step with pressing the two top coffee buttons)
    • Close the big lever and open it again. (Probably repeat it twice)
    • If it worked the machine gives a signal (beep). So it is resetted
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
Schlauer Bauer
Membre depuis le 10/01/2017
94 Réputation
1 tutoriel rédigé
For a tchibo cafissimo classic?
yasmin isabelle - Réponse
Hat überhaupt gar nicht funktioniert.
Bei meiner TchiboS Cafissimo classic sind auch die 3 Kaffeewahlknöpfe auf gleicher Höhe und es gibt somit keinen „obersten“ Knopf.
Kobe - Réponse
My machine is not working and the button light is blinking
Shouyab Shahin - Réponse
Not working,the lever has no switch or sensor so it doesn`t metter.Mine is flashing red with no beep and not respond to command.The level sensor for wather is ok,the temperature senzor from boiler is ok,the resistence of boiler is ok..so..maybe the software is the problem
Cici - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 45
7 derniers jours : 335
30 derniers jours : 1,582
Total : 53,740
