Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to restore a jammed drive in your coffee grinder
Ce dont vous avez besoin
    • Unplug the grinder from the mains before any work.
    • Spin the blade by hand to confirm it turns freely.
    • Residue that sets solid will stall the motor and cause overheating.
    Demander à FixBot
    Ajouter un commentaire
    • Undo the two external screws, including any hidden beneath rubber feet.
    • Lift off the decorative caps and store them safely for reassembly.
    Demander à FixBot
    • Slide out both springs and keep them paired for later.
    • Remove the metal strain-relief plate so the power cord can be freed.
    Demander à FixBot
    • Lock the rotor through the rear slot to stop it turning.
    • Turn the blade counter-clockwise until it comes off the shaft.
    • Lift the motor assembly out of the housing once the blade is removed.
    • Collect any washers that drop loose so they are not lost.
    Demander à FixBot
    • Brush loose residue from the shell and remove it with a vacuum cleaner.
    • Wash plastic parts in warm water with mild detergent and rinse well.
    • Dry every piece completely before any parts are refitted.
    Demander à FixBot
    • Dust the motor, main switch and lid safety interlock with a dry brush.
    • Blow the components with compressed air to clear hidden particles.
    • Confirm the safety interlock slides freely so the grinder cannot run with the lid open.
    Demander à FixBot
    • Pry the metal brush cap open gently to avoid snapping the small tab.
    • Slide each carbon brush out of its holder and check the remaining length.
    • Install two new brushes if either one is worn beyond its limit.
    • Press the cap shut and bend the tab back to secure the holder.
    Demander à FixBot
    • Scrape residue from the switch edges with a fingernail so the contacts move freely.
    Demander à FixBot
    • Apply a drop of light oil where plastic parts slide against each other.
    Demander à FixBot
    • Place the power cord and strain relief back into their recesses in the lower shell.
    • Slide the main switch into its slot with the soldered leads facing inward.
    Demander à FixBot
    • Press the lid interlock switch into the vertical slot until the clips lock.
    • Ensure the actuator sits flush so the lid pin will fully depress it during use.
    Demander à FixBot
    • Insert the two-tabbed plastic collar, rotate it 180° to lock in the housing.
    • Stack the felt ring and rubber gasket inside the collar to seal the motor chamber.
    Demander à FixBot
    • Align the motor with the blade opening and cable groove then lower it into place.
    • Compress the two springs, hold the motor down and insert the mounting screws.
    • Tighten the screws while maintaining pressure to keep the motor seated.
    Demander à FixBot
    • Snap the decorative caps back over the screw heads.
    • Thread the blade onto the shaft by hand; it will self-tighten when the grinder starts.
    Demander à FixBot
    • Plug the grinder in and run it briefly to verify a high-pitched, healthy sound.
    • Stop immediately if the motor labours or the tone is muffled.
    Demander à FixBot
Regularly brushing out coffee dust and keeping wet ingredients out of the grinder will stop future jams and overheating. Store the small springs, washers and caps safely so future maintenance remains simple, and always unplug before opening the housing.
Ula Gantar
Membre depuis le 01/08/25
16 609 Réputation
81 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 79
Total : 370
