Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to stop bicycle brakes from squeaking
Vues: 2,7 k
Afficher les statistiques :
Dernières 24 heures :
11
Sept derniers jours :
55
Trente derniers jours :
222
Total :
2 657
Commentaires: 1
1 commentaire d'étapes.
Terminé: 0
Personne n'a marqué ce tutoriel comme « terminé ». Serez-vous le premier ?
Favoris: 3
3 personnes ont mis ce tutoriel en favori (et s'y sont abonnées). Serez-vous la prochaine ?
Temps nécessaire: 5 - 10 minutes
Difficulté: Très facile
If the brakes on your bicycle are squeaking or doing a poor job slowing down your bike this guide will provide instruction to clean, adjust, or even replace the brake pads on your bicycle to rectify these issues.  This guide will also show you how to adjust your brake pads to be “toed-in” (the brake pads will be positioned in such a  way that the front part of the brake pad will make contact before the back half) to reduce further wear on the brake pads as well as increase their effectiveness.
Ce dont vous avez besoin
    1. How to stop bicycle brakes from squeaking, How to stop bicycle brakes from squeaking: étape 1, image 1 de 1
      • Loosen the brake pads from the calipers using a 10mm wrench.
      • You will need to repeat this step for the second brake pad located on the other side of the wheel.
      Demander à FixBot
      Ajouter un commentaire
    2. How to stop bicycle brakes from squeaking: étape 2, image 1 de 1
      • Remove the brake pads from the calipers.
      Demander à FixBot
    3. How to stop bicycle brakes from squeaking: étape 3, image 1 de 1
      • Clean the surface of the brake pad with a cloth or water if necessary.
      • The surface of the rims where the brake pads make contact may also need to be cleaned.
      Demander à FixBot
    4. How to stop bicycle brakes from squeaking: étape 4, image 1 de 1
      • Reattach the brake pads to the calipers and tighten them with the 10mm wrench so that the leading edge of the brake sits closer to the rim than the rear edge.
      Demander à FixBot
    5. How to stop bicycle brakes from squeaking: étape 5, image 1 de 1
      • Check the brake cable and make sure that it is still connected and secured to the brake calipers.
      Demander à FixBot
    6. How to stop bicycle brakes from squeaking: étape 6, image 1 de 1
      • Test the brake to ensure that it functions properly before riding the bike.
      Demander à FixBot
Kevin Colon
Membre depuis le 02/08/18
160 Réputation
1 tutoriel rédigé
Équipe
Pasco Hernando, Team S5-G34, Prince Spring 2018 Membre de l'équipe Pasco Hernando, Team S5-G34, Prince Spring 2018
PHSC-PRINCE-S18S5G34
1 membre
12 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 55
30 derniers jours : 222
Total : 2,657
