Aller au contenu principal
How to tighten the Razor A handlebar clamp
  1. How to tighten the Razor A handlebar clamp, How to tighten the Razor A handlebar clamp: étape 1, image 1 de 1
    • Locate the T-tube clamp. It is in the middle of the steering column.
  2. How to tighten the Razor A handlebar clamp: étape 2, image 1 de 2 How to tighten the Razor A handlebar clamp: étape 2, image 2 de 2
    • Open the clamp by pulling the lever away from the scooter.
  3. How to tighten the Razor A handlebar clamp: étape 3, image 1 de 2 How to tighten the Razor A handlebar clamp: étape 3, image 2 de 2
    • Locate the screw on the side of clamp.
    • Turn the screw on the side of the clamp by hand in a clockwise direction.
    • Attempt to close the clamp. If the lever is too tight to close, loosen the screw slightly and try again.
    • The T-tube should now be locked in place. If it continues to fall down, repeat the instructions in this guide.
Ligne d'arrivée
Jordyn
Membre depuis le 10/09/12
544 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 9-13, Amido Fall 2012 Membre de l'équipe Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 30
Total : 3,727
