Introduction
The following guide will teach you how to examine the wind screen, power cord, jack, and diaphragm.
Pièces
Aucune pièce nécessaire.
Remove the windscreen from the top of the microphone.
  • Remove the windscreen from the top of the microphone.
  • Once the foam windscreen is removed, examine the windscreen looking for thinning, holes, tears, or discoloration. Any of these issues may be the cause of the sound distortion.
Ajouter un commentaire
Locate the jack of the microphone and look for:  discoloration, rust, breaks in the piece, as well as making sure the jack is not bent or torn from the power cord.
  • Locate the jack of the microphone and look for: discoloration, rust, breaks in the piece, as well as making sure the jack is not bent or torn from the power cord.
  • Inspect the cord for splits, breaks, or loose wires. Check the cord from one end to the other, making sure the cord is attached to the microphone.
  • To check the cord further by unscrewing the bottom piece of the microphone from the top. Rotate clockwise to unscrew the bottom and examine.
  • Another to assessing distortion is to inspect the diaphragm. For further information, see the Diaphragm Examination Guide
  • Use a Phillips head (#00) screwdriver, to remove the diaphragm and separate the diaphragm from the base of the microphone.
  • Inspect the diaphragm checking to see if the piece is dirty, bent, or has holes. If it is bent or has holes, it may need to be replaced.
  • If the diaphragm is dirty, clean it with a dry towel or cotton swab by gently brushing dirt and/or rust off the piece.
Justin Lewis
Membre depuis le 23/01/2014
224 Réputation
2 tutoriels rédigés
Équipe
New Mexico State, Team 1-2, Sheppard Spring 2014 Membre de l'équipe New Mexico State, Team 1-2, Sheppard Spring 2014
NMSU-SHEPPARD-S14S1G2
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 5
Total : 399
