Aller au contenu principal
Hp 15-f305dx Keyboard Replacement
Ce dont vous avez besoin
  1. Hp 15-f305dx Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
  2. Hp 15-f305dx Keyboard Replacement: étape 2, image 1 de 1
    • Turn the computer upside down on a flat surface.
  3. Hp 15-f305dx Keyboard Replacement: étape 3, image 1 de 3 Hp 15-f305dx Keyboard Replacement: étape 3, image 2 de 3 Hp 15-f305dx Keyboard Replacement: étape 3, image 3 de 3
    • Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
  4. Hp 15-f305dx Keyboard Replacement: étape 4, image 1 de 2 Hp 15-f305dx Keyboard Replacement: étape 4, image 2 de 2
    • Lift the battery from the middle and then pivot it outward to remove it from the computer.
  5. Hp 15-f305dx Keyboard Replacement, Keyboard: étape 5, image 1 de 1
    • Flip the laptop around.
  6. Hp 15-f305dx Keyboard Replacement: étape 6, image 1 de 2 Hp 15-f305dx Keyboard Replacement: étape 6, image 2 de 2
    • Remove the single 7 mm screw from the top middle of the laptop using a Phillips #0 screwdriver.
  7. Hp 15-f305dx Keyboard Replacement: étape 7, image 1 de 2 Hp 15-f305dx Keyboard Replacement: étape 7, image 2 de 2
    • Pry the keyboard out of the laptop gently and flip the keyboard around.
  8. Hp 15-f305dx Keyboard Replacement: étape 8, image 1 de 1
    • Disconnect the connected cable from the mainboard.
Brandon
Membre depuis le 03/23/18
681 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G3, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G3, Bernier Spring 2018
UMASSD-BERNIER-S18S2G3
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 656
