Aller au contenu principal
Hp Pavilion dv6-2155dx Optical Drive Replacement
Ce dont vous avez besoin
  1. Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: étape 1, image 1 de 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: étape 1, image 2 de 2
    • Flip the computer around to the back side.
    • Remove the three screws from the memory module cover.
    • Screws will not come out all the way.
    • All screws to loosen/removed in this guide will require a Phillips #01 screwdriver.
  2. Hp Pavilion dv6-2155dx Optical  Drive Replacement: étape 2, image 1 de 1
    • Remove the screw completely from the memory module panel to help release the Optical drive from the body of the computer.
    • The screw is 7mm long and head is 4mm wide.
  3. Hp Pavilion dv6-2155dx Optical  Drive Replacement: étape 3, image 1 de 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement: étape 3, image 2 de 2
    • Locate the small hole next to the eject button.
    • Get a paper clip and insert in to the small hole until you hear a clicking sound and seeing the tray pop out.
    • Before removing the optical drive, be sure that there is nothing in the drive. Optical drives are fragile so handle with care.
  4. Hp Pavilion dv6-2155dx Optical  Drive Replacement: étape 4, image 1 de 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement: étape 4, image 2 de 2
    • Gently pull the Optical drive out of the slot until the whole thing comes out.
2 autres ont terminé cette réparation.
Joseph Sanda
Membre depuis le 03/10/16
522 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-2, Isaacson Fall 2016 Membre de l'équipe UMass Dartmouth, Team 2-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 13
Total : 799
