Aller au contenu principal
Huawei Ascend G610 Display Assembly Replacement
  1. Huawei Ascend G610 Display Assembly  Replacement, Display Assembly: étape 1, image 1 de 1
    • Rimuovere cover posteriore
  2. Huawei Ascend G610 Display Assembly  Replacement: étape 2, image 1 de 1
    • rimuovere batteria
  3. Huawei Ascend G610 Display Assembly  Replacement: étape 3, image 1 de 3 Huawei Ascend G610 Display Assembly  Replacement: étape 3, image 2 de 3 Huawei Ascend G610 Display Assembly  Replacement: étape 3, image 3 de 3
    • rimuovere con l'aiuto di un cacciavite a croce le 9 viti laterali che fissano la scocca posteriore
    • Attenzione 1 di queste è coperte da un adesivo
    • Rimuovere la vite centrale vicino alla slot sim card ,attenzione è più corta
  4. Huawei Ascend G610 Display Assembly  Replacement: étape 4, image 1 de 2 Huawei Ascend G610 Display Assembly  Replacement: étape 4, image 2 de 2
    • sganciare connettore display
  5. Huawei Ascend G610 Display Assembly  Replacement: étape 5, image 1 de 2 Huawei Ascend G610 Display Assembly  Replacement: étape 5, image 2 de 2
    • sganciare connettore sensore luminosità
  6. Huawei Ascend G610 Display Assembly  Replacement: étape 6, image 1 de 2 Huawei Ascend G610 Display Assembly  Replacement: étape 6, image 2 de 2
    • Sganciare connettore touch screen
  7. Huawei Ascend G610 Display Assembly  Replacement: étape 7, image 1 de 2 Huawei Ascend G610 Display Assembly  Replacement: étape 7, image 2 de 2
    • Sganciare connettore che unisce le due schede
  8. Huawei Ascend G610 Display Assembly  Replacement: étape 8, image 1 de 3 Huawei Ascend G610 Display Assembly  Replacement: étape 8, image 2 de 3 Huawei Ascend G610 Display Assembly  Replacement: étape 8, image 3 de 3
    • sganciare la scheda madre principale fissata su 3 punti ad incastro
  9. Huawei Ascend G610 Display Assembly  Replacement: étape 9, image 1 de 3 Huawei Ascend G610 Display Assembly  Replacement: étape 9, image 2 de 3 Huawei Ascend G610 Display Assembly  Replacement: étape 9, image 3 de 3
    • Con l'aiuto di un phon riscaldare la scheda attaccata con biadesivo
    • Con uno strumento sottile scalsarla da sotto delicatamente fino al completo distacco
  10. Huawei Ascend G610 Display Assembly  Replacement: étape 10, image 1 de 2 Huawei Ascend G610 Display Assembly  Replacement: étape 10, image 2 de 2
    • Rimuovere alloggio microfono
  11. Huawei Ascend G610 Display Assembly  Replacement: étape 11, image 1 de 3 Huawei Ascend G610 Display Assembly  Replacement: étape 11, image 2 de 3 Huawei Ascend G610 Display Assembly  Replacement: étape 11, image 3 de 3
    • con l'aiuto del phone rimuovere il flat tasti volume e spegnimento
  12. Huawei Ascend G610 Display Assembly  Replacement: étape 12, image 1 de 2 Huawei Ascend G610 Display Assembly  Replacement: étape 12, image 2 de 2
    • rimuovere speaker
  13. Huawei Ascend G610 Display Assembly  Replacement: étape 13, image 1 de 2 Huawei Ascend G610 Display Assembly  Replacement: étape 13, image 2 de 2
    • Rimuovere sensore di luminosità
  14. Huawei Ascend G610 Display Assembly  Replacement: étape 14, image 1 de 1
    • Col phon rimuovere adesivo delle specifiche telefono
  15. Huawei Ascend G610 Display Assembly  Replacement: étape 15, image 1 de 1
    • Adesso ripercorrere al contrario le fasi della guida rimontando i pezzi sul nuovo display assemblato con frame e touch screen
Per rimontare il dispositivo, segui queste istruzioni in ordine inverso.
3 autres ont terminé cette réparation.
Smilzo
Membre depuis le 11/09/13
11 267 Réputation
39 tutoriels rédigés
4 commentaires
Hi. Do you follow this procedure to replace a shattered screen? Where can I get the specialised little plastic tools designed to do this? Interesting. Thank.J.
jessemark05 - Réponse
hello, generally the tools are found together with the new display that you buy.  otherwise you can buy them online or at ifixit shop
Smilzo -
Got the tools needed,thanks for reply. Do I have to follow this complete procedure just to replace the screen? Jesse.
yes, this is the procedure to replace the complete frame display
Smilzo -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 5
Total : 2,332
