Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
It is a fairly simple and straightforward guide. Just be gentle when you're removing the parts. They can break easily.
  1. Flip the device over so that the back of the phone is facing you and the screen is against your palm.
    • Flip the device over so that the back of the phone is facing you and the screen is against your palm.
  2. Locate the slit at the bottom of the back cover.
    • Locate the slit at the bottom of the back cover.
    • Using your fingernail, lift up on the back cover to expose the battery.
  3. Lift the back cover off the phone.
    • Lift the back cover off the phone.
    • The back cover is snapped onto the phone so you will feel it unsnapping as you remove it.
  4. SAUTEZ LA MISE À NIVEAU
    Économisez en réparant avec un kit tout-en-un.
    Fix Kits pour iPhone
  5. Find the indented notch at the base of the battery. Lift the battery out of the phone with your fingers by pressing forward and lifting upward. Lift the battery out of the phone with your fingers by pressing forward and lifting upward.
    • Find the indented notch at the base of the battery.
    • Lift the battery out of the phone with your fingers by pressing forward and lifting upward.
  6. After removing the battery, remove the screws using a T6 screwdriver. There are eleven screws that hold the middle cover to the rest of the phone.
    • After removing the battery, remove the screws using a T6 screwdriver.
    • There are eleven screws that hold the middle cover to the rest of the phone.
    • The screw that is marked by the orange circle is covered by a white dot.
  7. After all the screws are removed, use your fingers to remove the lower section of the middle cover. Pull the lower section of the middle cover outward towards you, exposing the circuit board underneath. Pull the lower section of the middle cover outward towards you, exposing the circuit board underneath.
    • After all the screws are removed, use your fingers to remove the lower section of the middle cover.
    • Pull the lower section of the middle cover outward towards you, exposing the circuit board underneath.
  8. Begin working your way around the sides of the cover plate, unsnapping it gently. The middle cover is a thin piece of plastic with the external speaker inside of it. Be gentle as you remove circuit cover. The parts might break if you are too forceful.
    • Begin working your way around the sides of the cover plate, unsnapping it gently.
    • The middle cover is a thin piece of plastic with the external speaker inside of it.
    • Be gentle as you remove circuit cover. The parts might break if you are too forceful.
  9. The middle covers are removed. The antenna is a thin white wire that connects to the circuit board in two locations.
    • The middle covers are removed.
    • The antenna is a thin white wire that connects to the circuit board in two locations.
  10. Lift gently at each connector of the white wire to disconnect the antenna from the port. Lift gently at each connector of the white wire to disconnect the antenna from the port.
    • Lift gently at each connector of the white wire to disconnect the antenna from the port.
2 autre(s) ont terminé cette réparation.
Jaie Hillery
Membre depuis le 07/10/2014
1 561 Réputation
10 tutoriels rédigés
Équipe
USF Tampa, Team 16-6, Blackwell Winter 2016 Membre de l'équipe USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 membres
15 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 971
