Introduction
Use this guide to replace the loudspeaker in your Huawei Mate 8.
Switch off your phone and remove the SIM card tray.
  • Switch off your phone and remove the SIM card tray.
Ajouter un commentaire
Remove the Torx T2 screws from the bottom of the phone
  • Remove the Torx T2 screws from the bottom of the phone
  • Use an iSclack or a suction handle in the bottom area of your phone to separate the display unit from the rear panel.
  • Use an opening pick to fully separate the clips, releasing the phone.
    • Do not fully remove the rear case. The fingerprint sensor cable is still connected to the back cover.
  • Open the phone like a book from the SIM tray side.
  • Use a spudger, to disconnect the fingerprint sensor cable.
  • Remove the liquid indicator sticker.
  • Remove the Phillips #00 screw that holds down the metal shield.
  • The metal shield is tightly held in place. If you try to remove it without holding it down on one side, it'll break easily.
  • Use a spudger to remove the metal shield.
  • Use the flat end of a spudger to disconnect the display, daughterboard interconnect, and battery cables.
  • Remove the Phillips #00 screw that holds down the interconnect cable bracket.
  • Lift the coaxial connector off of its socket to allow access to the daughterboard interconnect cable bracket.
  • Remove the bracket.
  • Use a spudger to disconnect the interconnect cable.
  • Remove the interconnect cable.
  • Remove the two Phillips #00 screws.
  • Use the flat end a spudger to disconnect the loudspeaker flex connector.
  • Use the pointy end of a spudger to pry out the daughterboard.
  • Remove the daughterboard.
  • Use the tip of a spudger on the left side of the loudspeaker to pry it out.
  • Remove the loudspeaker.
Theo Mat
Membre depuis le 12/11/2017
7 872 Réputation
39 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 26
Total : 175
