Aller au contenu principal
Introduction
Unlike most tablets, the Huawei MediaPad M2 10.0 has a display assembly that is easy to remove, a big positive when looking at repair. The battery is incredibly difficult to remove, however, giving the tablet a 7 out of 10 on the repairability scale.
  1. Front/back reference shots. Front/back reference shots. Front/back reference shots.
    • Front/back reference shots.
  2. Simple plastic clips make opening easy. The display cable has enough slack to lay the display aside to work on the interior.
    • Simple plastic clips make opening easy.
    • The display cable has enough slack to lay the display aside to work on the interior.
  3. Display assembly carries: display interconnect cable, home button/fingerprint reader and cable, and its bracket.
    • Display assembly carries: display interconnect cable, home button/fingerprint reader and cable, and its bracket.
    • Home button/fingerprint reader is easily removed and replaced.
  4. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  5. The battery is glued to the rear case by very strong adhesive. Heat, adhesive removal fluid, and much prying, the battery is removed.
    • The battery is glued to the rear case by very strong adhesive.
    • Heat, adhesive removal fluid, and much prying, the battery is removed.
    • Frustrating that an inevitable repair/replacement would be this hard, but at least it isn't blocking other components' replacement.
  6. The bracket over the speaker and button/headphone jack cable has two different kinds of screws, Torx and Phillips, making removal obnoxious. Removable in parallel with the battery are: lower speaker, speaker/antennas, brackets, and microphone bumper.
    • The bracket over the speaker and button/headphone jack cable has two different kinds of screws, Torx and Phillips, making removal obnoxious.
    • Removable in parallel with the battery are: lower speaker, speaker/antennas, brackets, and microphone bumper.
    • SIM tray can be removed while the device is sealed, obviously.
  7. The final components out of the rear case are fairly modular:
    • The final components out of the rear case are fairly modular:
    • SIM reader and vibrator assembly
    • Headphone jack and button cable assembly
    • Front and rear facing cameras
    • Motherboard, unfortunately has a soldered-on charging port. That means a more expensive repair for a common failure point.
  8. The Huawei MediaPad M2 earns a 7 out of 10 on our repairability scale (10 is the easiest to repair): The display is easily removed from the simple clips holding it to the body, simplifying repairs.
    • The Huawei MediaPad M2 earns a 7 out of 10 on our repairability scale (10 is the easiest to repair):
    • The display is easily removed from the simple clips holding it to the body, simplifying repairs.
    • Most components are modular and not overly complex.
    • The battery is extremely difficult to remove, even with heat and prying.
    • The charging port is soldered to the motherboard, making replacement of this high-use component expensive.
    • Manufacturer does not provide user-accessible repair documentation.
Ligne d'arrivée
3 autre(s) ont terminé cette réparation.
Andrew Optimus Goldheart
Membre depuis le 17/10/2009
417 361 Réputation
411 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
98 membres
8 948 tutoriels rédigés
Does the display assembly have any glue?
Where does one start from to pry open the screen assembly and is the MediaPad m3 similar to this?
Will be much obliged if you could throw some light on it.
Rajendra Maini - Réponse
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 7
7 derniers jours : 33
30 derniers jours : 199
Total : 5,558
