Introduction
Although the display of the P10 carries all the parts and calls for an extensive repair when it brakes, all other repairs are fairly simple.
Fancy toolbox style packaging.
  • Fancy toolbox style packaging.
  • Front and back reference photos.
Ajouter un commentaire
Two Pentalobe P2 screws on the bottom.
  • Two Pentalobe P2 screws on the bottom.
  • Remove the SIM card.
  • Prying the case open with a plastic opening tool.
  • The fingerprint sensor ist still connected to the motherboard.
  • The fingerprint sensor can be unplugged easily with a spudger.
  • Two metal brackets—one of the screws covered with a liquid indicator—secure the battery and interconnect cables as well as the display cable.
  • The battery is held in place by two adhesive strip of which one of them has a pull tab for easy removal.
  • The loudspeaker is glued in place with a mild adhesive.
  • With the metal shield removed we can unplug the interconnect cable, the antenna cable and the headphone connector.
  • The headphone jack and the daughterboard come out easily.
  • The vibrator is held in place by a mild adhesive.
  • Both cameras are easy to remove. The connector of the dual camera is secured by a metal bracket.
  • Three more Phillips screws hold the motherboard in place.
  • The earpiece speaker and the proximity and brightness sensor are fixed by mild adhesives.
  • The power and volume button bracket can be removed very easily with a tweezers.
  • With a little bit of heating one of the display corners can be lifted with an opening pick.
  • The adhesive on the side is cut with a halberd spudger.
  • Now the display cable can be thread through the frame.
  • The Huawei P10 earns a 6 out of 10 on our repairability scale (10 is the easiest to repair):
    • Many components are modular and can be replaced independently.
    • Only standard Phillips screws are used.
    • Except for the two Pentalobe screws on the bottom.
    • The battery can be replaced after removing a few cables and has a pull tab on one adhesive strip.
    • Components are adhered to the back of the fused display.
Ligne d'arrivée
2 autre(s) ont terminé cette réparation.
Tobias Isakeit
Membre depuis le 31/03/2014
28 451 Réputation
227 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
109 membres
6 277 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 100
Total : 1,504
