Aller au contenu principal
Huawei P8 Lite Motherboard Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Huawei P8 Lite Motherboard Replacement, Back Cover: étape 1, image 1 de 2 Huawei P8 Lite Motherboard Replacement, Back Cover: étape 1, image 2 de 2
    • Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
  2. Huawei P8 Lite Motherboard Replacement: étape 2, image 1 de 3 Huawei P8 Lite Motherboard Replacement: étape 2, image 2 de 3 Huawei P8 Lite Motherboard Replacement: étape 2, image 3 de 3
    • There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool.
    • When all clips are open, remove the back cover from the rest of the phone.
    • If the back cover doesn't come freely, there are probably some additional clips that need to be disconnected.
  3. Huawei P8 Lite Motherboard Replacement, Loudspeaker: étape 3, image 1 de 1
    • Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
  4. Huawei P8 Lite Motherboard Replacement: étape 4, image 1 de 1
    • Remove the 4 black Torx T5 screws which hold down the lower part of the loudspeaker.
    • Remove the three silver Phillips #00 screws which hold down the upper part of the loudspeaker.
  5. Huawei P8 Lite Motherboard Replacement: étape 5, image 1 de 1
    • Remove the loudspeaker carefully.
  6. Huawei P8 Lite Motherboard Replacement, Motherboard: étape 6, image 1 de 1
    • Continue by removing the SIM and SD card trays on the side of the device.
  7. Huawei P8 Lite Motherboard Replacement: étape 7, image 1 de 3 Huawei P8 Lite Motherboard Replacement: étape 7, image 2 de 3 Huawei P8 Lite Motherboard Replacement: étape 7, image 3 de 3
    • Remove the two Torx T5 screws. One may be cover with a liquid indicator.
    • Remove the five Phillips #000 screws.
    • Take away both securing brackets covering the motherboard.
    • If your phone has an NFC antenna, taking away the cover will automatically free its flex connector from the motherboard.
  8. Huawei P8 Lite Motherboard Replacement: étape 8, image 1 de 1
    • Remove the three Phillips #000 screws on the silver panel.
  9. Huawei P8 Lite Motherboard Replacement: étape 9, image 1 de 2 Huawei P8 Lite Motherboard Replacement: étape 9, image 2 de 2
    • Carefully separate the four connectors holding the motherboard in place.
    • Remove the motherboard from the device.
6 autres ont terminé cette réparation.
John Poffenberger
Membre depuis le 02/16/17
356 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-1, Kass Spring 2017 Membre de l'équipe USF Tampa, Team 1-1, Kass Spring 2017
USFT-KASS-S17S1G1
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,104
