Aller au contenu principal
Huawei P9 Back Cover
Ce dont vous avez besoin
  1. Huawei P9 Back Cover, Back Cover: étape 1, image 1 de 3 Huawei P9 Back Cover, Back Cover: étape 1, image 2 de 3 Huawei P9 Back Cover, Back Cover: étape 1, image 3 de 3
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Back Cover: étape 2, image 1 de 2 Huawei P9 Back Cover: étape 2, image 2 de 2
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Back Cover, Fingerprint sensor: étape 3, image 1 de 2 Huawei P9 Back Cover, Fingerprint sensor: étape 3, image 2 de 2
    • Disconnect the fingerprint sensor using a spudger.
7 autres ont terminé cette réparation.
Tobias Isakeit
Membre depuis le 03/31/14
119 540 Réputation
189 tutoriels rédigés
Équipe
Tobias Isakeit - Repairability Engineer Membre de l'équipe Tobias Isakeit - Repairability Engineer
Business
1 membre
1 093 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 20
Total : 9,010
