Aller au contenu principal
Introduction
Use this guide to replace the front facing camera in your Huawei P9.
  1. First switch off your phone and remove the SIM card tray. Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port. If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Use an iSclack or a suction handle to separate the display unit from the rear panel. Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
    • Use an iSclack or a suction handle to separate the display unit from the rear panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Fix Kits pour iPhone X
    Finie la garantie ? Pas de soucis, nous avons de quoi réparer.
    Acheter maintenant
    Acheter maintenant
  4. Disconnect the fingerprint sensor using a spudger. Disconnect the fingerprint sensor using a spudger.
    • Disconnect the fingerprint sensor using a spudger.
  5. Peel off the conducting fabric. You will have to transfer it to the new camera (careful it's sticky). Unplug the camera connector.
    • Peel off the conducting fabric.
    • You will have to transfer it to the new camera (careful it's sticky).
    • Unplug the camera connector.
    • Now you can remove the front camera.
Dominik Schnabelrauch
Membre depuis le 23/11/2016
38 517 Réputation
189 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
99 membres
9 204 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 21
Total : 999
