Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
The motherboard is the most important part in any electronic, It allows all the parts to work together. This guide will show you how to open the phone and get to the motherboards to replace it.
Pièces
Aucune pièce spécifiée.
  1. Use the opening tool from the iFixit kit to get under the back cover and, gently separate the back from the front. Use the opening tool from the iFixit kit to get under the back cover and, gently separate the back from the front. Use the opening tool from the iFixit kit to get under the back cover and, gently separate the back from the front.
    • Use the opening tool from the iFixit kit to get under the back cover and, gently separate the back from the front.
  2. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  3. Remove the 15 screws on the back of the phone  with a Phillips #000 screwdriver. Remove the 15 screws on the back of the phone  with a Phillips #000 screwdriver.
    • Remove the 15 screws on the back of the phone with a Phillips #000 screwdriver.
  4. Disconnect the connectors from the motherboard and gently remove the motherboard. Disconnect the connectors from the motherboard and gently remove the motherboard. Disconnect the connectors from the motherboard and gently remove the motherboard.
    • Disconnect the connectors from the motherboard and gently remove the motherboard.
Ryan Mascia
Membre depuis le 21/09/2018
97 Réputation
1 tutoriel rédigé
Équipe
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 94
