Aller au contenu principal
Huawei Pronto LTE Display Screen Assembly Replacement
Ce dont vous avez besoin
  1. Huawei Pronto LTE Display Screen Assembly Replacement, Battery: étape 1, image 1 de 2 Huawei Pronto LTE Display Screen Assembly Replacement, Battery: étape 1, image 2 de 2
    • Remove the back cover of your Huawei Pronto LTE using an opening tool.
    • Lift the back cover off of the device after the four corners are unlatched.
  2. Huawei Pronto LTE Display Screen Assembly Replacement: étape 2, image 1 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: étape 2, image 2 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: étape 2, image 3 de 3
    • Remove the 15 screws on the back of the device using a Phillips #000 screwdriver.
    • Hold the device in place while you are doing this step.
    • Lift the inner cover gently by using a spudger.
  3. Huawei Pronto LTE Display Screen Assembly Replacement: étape 3, image 1 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: étape 3, image 2 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: étape 3, image 3 de 3
    • Detach the yellow latches along the sides to remove the motherboard.
  4. Huawei Pronto LTE Display Screen Assembly Replacement: étape 4, image 1 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: étape 4, image 2 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: étape 4, image 3 de 3
    • Ensure that all latches are detached and that there are no extra screws to avoid damaging the motherboard.
    • Use tweezers to gently remove the motherboard from the device.
  5. Huawei Pronto LTE Display Screen Assembly Replacement: étape 5, image 1 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: étape 5, image 2 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: étape 5, image 3 de 3
    • The battery should be revealed once the motherboard is removed.
    • Lift the battery from the top left corner.
  6. Huawei Pronto LTE Display Screen Assembly Replacement, Screen Assembly: étape 6, image 1 de 2 Huawei Pronto LTE Display Screen Assembly Replacement, Screen Assembly: étape 6, image 2 de 2
    • Remove the motherboard. Refer to the Motherboard Replacement Guide.
    • Remove the battery.
  7. Huawei Pronto LTE Display Screen Assembly Replacement: étape 7, image 1 de 2 Huawei Pronto LTE Display Screen Assembly Replacement: étape 7, image 2 de 2
    • Once the battery is removed the screen will be visible.
Crystal Edwards
Membre depuis le 09/21/18
450 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 72
