Aller au contenu principal
Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: étape 1, image 1 de 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: étape 1, image 2 de 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: étape 1, image 3 de 3
    • Turn off the device
    • Remove the sim tray
  2. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: étape 2, image 1 de 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: étape 2, image 2 de 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: étape 2, image 3 de 3
    • Use Plastic tool to separate the back cover
    • With a Phillips screwdriver remove two black screws and the battery flex connector shield
    • Disconnect the battery and the finger print sensor flex cable
  3. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: étape 3, image 1 de 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: étape 3, image 2 de 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: étape 3, image 3 de 3
    • Remove all screws from the top of the logic board
    • Remove the shield covering the camera connectors
    • Remove the screws and the plastic cover at the bottom of the device
    • Be careful! Different colored screws have different size
  4. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: étape 4, image 1 de 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: étape 4, image 2 de 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: étape 4, image 3 de 3
    • Disconnect the Screen Flex cable
    • Remove the logic board
    • Note that at the bottom side of board is attached to the display with double-sided tape
  5. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: étape 5, image 1 de 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: étape 5, image 2 de 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: étape 5, image 3 de 3
    • Now you have to transfer:
    • Receiver
    • Proximity sensor
    • Volume buttons flex
    • Vibration
    • Battery
11 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
191 368 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 545 tutoriels rédigés
Un commentaire
Can i get video guide
filmon - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 91
Total : 6,615
