Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Husqvarna FE 350 Rear Sprocket Replacement
Ce dont vous avez besoin
  1. Husqvarna FE 350 Rear Sprocket Replacement, Rear Sprocket: étape 1, image 1 de 1
    • Place the motorcycle on a stand so that the rear tire is off the ground.
    Demander à FixBot
    Ajouter un commentaire
  2. Husqvarna FE 350 Rear Sprocket Replacement: étape 2, image 1 de 2 Husqvarna FE 350 Rear Sprocket Replacement: étape 2, image 2 de 2
    • Use the 27mm wrench to unscrew the nut that holds the axle together. This nut is located on the right side of the motorcycle at the end of the swing-arm.
    Demander à FixBot
  3. Husqvarna FE 350 Rear Sprocket Replacement: étape 3, image 1 de 3 Husqvarna FE 350 Rear Sprocket Replacement: étape 3, image 2 de 3 Husqvarna FE 350 Rear Sprocket Replacement: étape 3, image 3 de 3
    • Move to the left side of the motorcycle and remove the axle by pulling it directly out.
    • Move back to the right side and remove the spacer shown in the third picture to ensure that is does not get lost.
    Demander à FixBot
  4. Husqvarna FE 350 Rear Sprocket Replacement: étape 4, image 1 de 2 Husqvarna FE 350 Rear Sprocket Replacement: étape 4, image 2 de 2
    • Pull up and back on the chain to free the tire.
    Demander à FixBot
  5. Husqvarna FE 350 Rear Sprocket Replacement: étape 5, image 1 de 1
    • Lay the tire on a flat surface with with sprocket facing up.
    • Use the 6mm Torx wrench to unscrew the six bolts holding the sprocket on.
    • Replace the sprocket and screw the bolts back in.
    Demander à FixBot
  6. Husqvarna FE 350 Rear Sprocket Replacement: étape 6, image 1 de 1
    • Be careful that the brake rotor fits in between the brake pads on the caliper.
    Demander à FixBot
  7. Husqvarna FE 350 Rear Sprocket Replacement: étape 7, image 1 de 1
    • Put the chain back on. Start at the bottom and work the chain carefully over the top of the new sprocket.
    Demander à FixBot
  8. Husqvarna FE 350 Rear Sprocket Replacement: étape 8, image 1 de 3 Husqvarna FE 350 Rear Sprocket Replacement: étape 8, image 2 de 3 Husqvarna FE 350 Rear Sprocket Replacement: étape 8, image 3 de 3
    • Push the axle back through the swing arm and the wheel.
    • Place the spacer back onto the axle with the square side pointing forward.
    • Thread the 27mm nut back onto the axle.
    Demander à FixBot
  9. Husqvarna FE 350 Rear Sprocket Replacement: étape 9, image 1 de 1
    • Use the 27mm wrench to tighten the nut down.
    Demander à FixBot
Ligne d'arrivée
3 autres ont terminé cette réparation.
1 commentaire de tutoriel
C'est bien. je veux apprendre à réparer les motos
Enoch DEMBELE - Réponse Partager
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 33
30 derniers jours : 138
Total : 3,058
