Aller au contenu principal
Husqvarna Viking Designer 1 Needle Replacement
Ce dont vous avez besoin
  1. Husqvarna Viking Designer 1 Needle Replacement, Needle: étape 1, image 1 de 2 Husqvarna Viking Designer 1 Needle Replacement, Needle: étape 1, image 2 de 2
    • Remove the thread from the needle by pulling it out.
  2. Husqvarna Viking Designer 1 Needle Replacement: étape 2, image 1 de 3 Husqvarna Viking Designer 1 Needle Replacement: étape 2, image 2 de 3 Husqvarna Viking Designer 1 Needle Replacement: étape 2, image 3 de 3
    • Turn the knob counterclockwise to life up the needle.
    • Turning the knob clockwise can damage the machine.
  3. Husqvarna Viking Designer 1 Needle Replacement: étape 3, image 1 de 1
    • Place a sheet of paper under the foot. In the event that the needle falls out, this will prevent it from falling into the bobbin area.
  4. Husqvarna Viking Designer 1 Needle Replacement: étape 4, image 1 de 2 Husqvarna Viking Designer 1 Needle Replacement: étape 4, image 2 de 2
    • Hold onto the needle with one hand, and use a Singer #412381501 screwdriver to loosen the needle clamp screw (model: Viking #4125825-01) located next to the top of the needle with the other hand.
  5. Husqvarna Viking Designer 1 Needle Replacement: étape 5, image 1 de 1
    • Discard the broken or unwanted needle, and select a new one.
  6. Husqvarna Viking Designer 1 Needle Replacement: étape 6, image 1 de 2 Husqvarna Viking Designer 1 Needle Replacement: étape 6, image 2 de 2
    • Insert the new needle with the flat side facing away from you.
  7. Husqvarna Viking Designer 1 Needle Replacement: étape 7, image 1 de 1
    • Hold onto the needle with one hand, and use a Singer #412381501 screwdriver to tighten the needle clamp screw (model: Viking #4125825-01) with the other hand.
  8. Husqvarna Viking Designer 1 Needle Replacement: étape 8, image 1 de 1
    • Thread the needle. (See pages 8-10 from the link.)
    • You may now remove the sheet of paper and begin sewing!
Replacing the needle is a quick, easy task to complete, using the directions provided in this guide.
Un commentaire
Excellent illustration!!!
KO SAMUEL TAK SHUN - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 46
Total : 1,274
