Aller au contenu principal
HyperX Alloy Origins Frontplate Replacement
Ce dont vous avez besoin
  1. HyperX Alloy Origins Frontplate Replacement, Toggle Indicator Tab: étape 1, image 1 de 1
    • Locate the toggle indicator tab on the top right corner of the keyboard.
  2. HyperX Alloy Origins Frontplate Replacement: étape 2, image 1 de 2 HyperX Alloy Origins Frontplate Replacement: étape 2, image 2 de 2
    • Insert the metal spudger or some other separating instrument into the right crevasse between the tab and the keyboard.
    • Lift up gently on the tab, while holding the left side of the tab down.
    • The tab can spring upwards upon removal. Eye protection is recommended during this step.
  3. HyperX Alloy Origins Frontplate Replacement, Backplate: étape 3, image 1 de 2 HyperX Alloy Origins Frontplate Replacement, Backplate: étape 3, image 2 de 2
    • Flip the keyboard over so that the backplate is facing you.
  4. HyperX Alloy Origins Frontplate Replacement: étape 4, image 1 de 3 HyperX Alloy Origins Frontplate Replacement: étape 4, image 2 de 3 HyperX Alloy Origins Frontplate Replacement: étape 4, image 3 de 3
    • Remove the rubber feet on the four corners of the backplate.
    • When reassembling, use an adhesive to reattach the feet. A silicone rubber adhesive is recommended.
  5. HyperX Alloy Origins Frontplate Replacement: étape 5, image 1 de 3 HyperX Alloy Origins Frontplate Replacement: étape 5, image 2 de 3 HyperX Alloy Origins Frontplate Replacement: étape 5, image 3 de 3
    • Remove the specified keycaps as depicted in the image.
  6. HyperX Alloy Origins Frontplate Replacement: étape 6, image 1 de 3 HyperX Alloy Origins Frontplate Replacement: étape 6, image 2 de 3 HyperX Alloy Origins Frontplate Replacement: étape 6, image 3 de 3
    • Remove all Philips #0 screws from the new openings created after removing the rubber feet and plastic tab.
  7. HyperX Alloy Origins Frontplate Replacement: étape 7, image 1 de 3 HyperX Alloy Origins Frontplate Replacement: étape 7, image 2 de 3 HyperX Alloy Origins Frontplate Replacement: étape 7, image 3 de 3
    • Separate the backplate from the keyboard using your hands.
  8. HyperX Alloy Origins Frontplate Replacement, Key Switch: étape 8, image 1 de 3 HyperX Alloy Origins Frontplate Replacement, Key Switch: étape 8, image 2 de 3 HyperX Alloy Origins Frontplate Replacement, Key Switch: étape 8, image 3 de 3
    • Identify the key switch to be replaced.
    • Remove its keycap by carefully prying it off of the keyboard with your fingers.
  9. HyperX Alloy Origins Frontplate Replacement: étape 9, image 1 de 2 HyperX Alloy Origins Frontplate Replacement: étape 9, image 2 de 2
    • Flip the keyboard over to face the PCB.
    • Identify the corresponding switch to be removed.
  10. HyperX Alloy Origins Frontplate Replacement: étape 10, image 1 de 1
    • Plug in and turn on your soldering iron.
    • Do not touch the metal end of the soldering iron while it is powered on. Allow the soldering iron to cool before stowing it away.
  11. HyperX Alloy Origins Frontplate Replacement: étape 11, image 1 de 3 HyperX Alloy Origins Frontplate Replacement: étape 11, image 2 de 3 HyperX Alloy Origins Frontplate Replacement: étape 11, image 3 de 3
    Outil utilisé dans cette étape :
    Desoldering Pump
    $3.99
    J'achète
    • Melt the solder surrounding the four pins of the switch's LED, and the two lower pins of the switch body.
    • To remove the melted solder, use a desoldering iron, a desoldering pump, or desoldering braid.
    • The exposed switch pins are susceptible to damage from the soldering iron. Avoid applying heavy pressure to mitigate pin bending.
  12. HyperX Alloy Origins Frontplate Replacement: étape 12, image 1 de 1
    • Using a spudger or another metallic instrument, firmly press down upon the exposed plastic of the switch. This will separate the switch from the rest of the keyboard.
    • If the switch's pins will not separate from the keyboard's PCB, continue applying the soldering iron to the pins to melt any residual solder.
  13. HyperX Alloy Origins Frontplate Replacement, Frontplate: étape 13, image 1 de 1
    • Desolder and separate every key switch from the keyboard.
    • The keyboard microcontrollers should remain on the PCB and should not be desoldered.
    • Separate the frontplate from the keyboard PCB using your hands.
    • Set the PCB aside upon the backplate.
To reassemble your device, follow these instructions in reverse order. Note that when reattaching the switches back onto the keyboard PCB, the switches need to be held in place behind the keyboard while soldering.
Zachary Lapalme
Membre depuis le 10/25/22
85 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 5-2, Sinclaire Fall 2022 Membre de l'équipe UMass Dartmouth, Team 5-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G2
5 membres
15 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 50
Total : 735
