Aller au contenu principal
HyperX QuadCast S I/O Board Replacement
Ce dont vous avez besoin
  1. HyperX QuadCast S I/O Board Replacement, Gain Control Knob: étape 1, image 1 de 3 HyperX QuadCast S I/O Board Replacement, Gain Control Knob: étape 1, image 2 de 3 HyperX QuadCast S I/O Board Replacement, Gain Control Knob: étape 1, image 3 de 3
    • Set the microphone on a flat surface.
    • Pull each of the support bands upwards and off of the notches to release the microphone from its base.
    • There are four support bands in total, but it does not matter which band you choose to take off first.
  2. HyperX QuadCast S I/O Board Replacement: étape 2, image 1 de 3 HyperX QuadCast S I/O Board Replacement: étape 2, image 2 de 3 HyperX QuadCast S I/O Board Replacement: étape 2, image 3 de 3
    • Orientate the microphone with the gain control knob upwards.
    • Pull outwards from the microphone to release the gain control knob.
    • It will not take much force to release the knob from the microphone. Be aware that a small "pop" may be heard once the knob is unplugged.
  3. HyperX QuadCast S I/O Board Replacement: étape 3, image 1 de 3 HyperX QuadCast S I/O Board Replacement: étape 3, image 2 de 3 HyperX QuadCast S I/O Board Replacement: étape 3, image 3 de 3
    • Remove the gain control knob.
    • The gain control knob connects to the tiny black pin indicated. When reattaching the knob, make sure to properly align the hole to the shape of the pin.
  4. HyperX QuadCast S I/O Board Replacement, I/O Board: étape 4, image 1 de 2 HyperX QuadCast S I/O Board Replacement, I/O Board: étape 4, image 2 de 2
    • Remove the three 6 mm Phillips #0 screws.
  5. HyperX QuadCast S I/O Board Replacement: étape 5, image 1 de 3 HyperX QuadCast S I/O Board Replacement: étape 5, image 2 de 3 HyperX QuadCast S I/O Board Replacement: étape 5, image 3 de 3
    • Begin to pull out the I/O board.
    • Unplug any cables connected to the I/O board.
    • Some of the cables will need to be soldered back to any replacement I/O board to function properly.
  6. HyperX QuadCast S I/O Board Replacement: étape 6, image 1 de 2 HyperX QuadCast S I/O Board Replacement: étape 6, image 2 de 2
    • Finish pulling out the I/O board to remove it from the microphone.
Nathan Arruda
Membre depuis le 10/25/22
684 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-1, Sinclaire Fall 2022 Membre de l'équipe UMass Dartmouth, Team 4-1, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G1
5 membres
9 tutoriels rédigés
2 commentaires
I need a replacement io board, does ifixit or anyone else have them?
josh bryant - Réponse
Unfortunately HyperX does not sell the replacement parts separately. Your best bet is to find a scrap quad-cast to pull parts from.
Nathan Arruda -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 16
7 derniers jours : 44
30 derniers jours : 140
Total : 1,717
