Aller au contenu principal
Hytera TC-580 Microphone Replacement
Ce dont vous avez besoin
  1. Hytera TC-580 Microphone Replacement, Battery: étape 1, image 1 de 2 Hytera TC-580 Microphone Replacement, Battery: étape 1, image 2 de 2
    • Remove the two 10mm Phillips #0 from the belt clip.
  2. Hytera TC-580 Microphone Replacement: étape 2, image 1 de 2 Hytera TC-580 Microphone Replacement: étape 2, image 2 de 2
    • Push in the release button and pull up on the battery to remove.
  3. Hytera TC-580 Microphone Replacement, Antenna: étape 3, image 1 de 1
    • Twist antenna counter-clockwise and set damaged antenna aside.
  4. Hytera TC-580 Microphone Replacement, Keypad: étape 4, image 1 de 1
    • Remove the volume knob by firmly lifting up on both sides of it.
  5. Hytera TC-580 Microphone Replacement: étape 5, image 1 de 1
    • Remove the orange o-ring around volume knob using tweezers.
  6. Hytera TC-580 Microphone Replacement: étape 6, image 1 de 1
    • Remove grey nut from base of volume knob by turning it counterclockwise with a set of tweezers.
  7. Hytera TC-580 Microphone Replacement: étape 7, image 1 de 1
    • Remove the brass washer from the base of the antenna slot by turning it counterclockwise with a set of tweezers.
  8. Hytera TC-580 Microphone Replacement: étape 8, image 1 de 2 Hytera TC-580 Microphone Replacement: étape 8, image 2 de 2
    • Remove the two 15mm T8 Torx screws from the base of the battery cavity.
  9. Hytera TC-580 Microphone Replacement: étape 9, image 1 de 1
    • Using a plastic opening tool, pry in between the plastic case and metal circuit board to remove the board.
  10. Hytera TC-580 Microphone Replacement: étape 10, image 1 de 1
    • Peel off the keypad by hand.
  11. Hytera TC-580 Microphone Replacement, Speaker: étape 11, image 1 de 3 Hytera TC-580 Microphone Replacement, Speaker: étape 11, image 2 de 3 Hytera TC-580 Microphone Replacement, Speaker: étape 11, image 3 de 3
    • Remove eleven 4mm Phillips #00 screws.
  12. Hytera TC-580 Microphone Replacement: étape 12, image 1 de 1
    • Apply a soldering iron to the solder joints to remove the two wires connecting the speaker to the circuit board.
  13. Hytera TC-580 Microphone Replacement, Microphone: étape 13, image 1 de 1
    • If not already done, remove the circuit board completely from the case.
  14. Hytera TC-580 Microphone Replacement: étape 14, image 1 de 1
    • Desolder the two microphone solder joints.
  15. Hytera TC-580 Microphone Replacement: étape 15, image 1 de 1
    • The microphone should fall out after all the solder has been removed.
Stuart
Membre depuis le 02/14/18
464 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S3-G4, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S3-G4, Nance Spring 2018
USFT-NANCE-S18S3G4
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 17
Total : 720
