Aller au contenu principal
Hytera TC-580 Speaker Replacement
Ce dont vous avez besoin
  1. Hytera TC-580 Speaker Replacement, Battery: étape 1, image 1 de 2 Hytera TC-580 Speaker Replacement, Battery: étape 1, image 2 de 2
    • Remove the two 10mm Phillips #0 from the belt clip.
  2. Hytera TC-580 Speaker Replacement: étape 2, image 1 de 2 Hytera TC-580 Speaker Replacement: étape 2, image 2 de 2
    • Push in the release button and pull up on the battery to remove.
  3. Hytera TC-580 Speaker Replacement, Antenna: étape 3, image 1 de 1
    • Twist antenna counter-clockwise and set damaged antenna aside.
  4. Hytera TC-580 Speaker Replacement, Keypad: étape 4, image 1 de 1
    • Remove the volume knob by firmly lifting up on both sides of it.
  5. Hytera TC-580 Speaker Replacement: étape 5, image 1 de 1
    • Remove the orange o-ring around volume knob using tweezers.
  6. Hytera TC-580 Speaker Replacement: étape 6, image 1 de 1
    • Remove grey nut from base of volume knob by turning it counterclockwise with a set of tweezers.
  7. Hytera TC-580 Speaker Replacement: étape 7, image 1 de 1
    • Remove the brass washer from the base of the antenna slot by turning it counterclockwise with a set of tweezers.
  8. Hytera TC-580 Speaker Replacement: étape 8, image 1 de 2 Hytera TC-580 Speaker Replacement: étape 8, image 2 de 2
    • Remove the two 15mm T8 Torx screws from the base of the battery cavity.
  9. Hytera TC-580 Speaker Replacement: étape 9, image 1 de 1
    • Using a plastic opening tool, pry in between the plastic case and metal circuit board to remove the board.
  10. Hytera TC-580 Speaker Replacement: étape 10, image 1 de 1
    • Peel off the keypad by hand.
  11. Hytera TC-580 Speaker Replacement, Speaker: étape 11, image 1 de 3 Hytera TC-580 Speaker Replacement, Speaker: étape 11, image 2 de 3 Hytera TC-580 Speaker Replacement, Speaker: étape 11, image 3 de 3
    • Remove eleven 4mm Phillips #00 screws.
  12. Hytera TC-580 Speaker Replacement: étape 12, image 1 de 1
    • Apply a soldering iron to the solder joints to remove the two wires connecting the speaker to the circuit board.
Mohammed Chehab
Membre depuis le 02/14/18
88 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S3-G4, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S3-G4, Nance Spring 2018
USFT-NANCE-S18S3G4
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 7
Total : 499
