Aller au contenu principal
IBM ThinkPad 560z Keyboard Cover Replacement
Ce dont vous avez besoin
  1. IBM ThinkPad 560z Keyboard Cover Replacement, Upper Case: étape 1, image 1 de 1
    • Remove the 7 mm Phillips #0 screws.
    • Remove the 10 mm Phillips #0 screws.
    • Remove the 14 mm Phillips #0 screw.
  2. IBM ThinkPad 560z Keyboard Cover Replacement: étape 2, image 1 de 2 IBM ThinkPad 560z Keyboard Cover Replacement: étape 2, image 2 de 2
    • Open the flap on the left hand side.
  3. IBM ThinkPad 560z Keyboard Cover Replacement: étape 3, image 1 de 2 IBM ThinkPad 560z Keyboard Cover Replacement: étape 3, image 2 de 2
    • Insert the plastic opening tools between the right and left sides of the latch.
    • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
  4. IBM ThinkPad 560z Keyboard Cover Replacement: étape 4, image 1 de 2 IBM ThinkPad 560z Keyboard Cover Replacement: étape 4, image 2 de 2
    • Open the flap on the right side.
  5. IBM ThinkPad 560z Keyboard Cover Replacement: étape 5, image 1 de 1
    • Insert the plastic opening tools towards the right side of the latch.
    • Gently pry the right side out to release the top cover.
  6. IBM ThinkPad 560z Keyboard Cover Replacement: étape 6, image 1 de 2 IBM ThinkPad 560z Keyboard Cover Replacement: étape 6, image 2 de 2
    • Lift the keyboard slowly.
    • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  7. IBM ThinkPad 560z Keyboard Cover Replacement: étape 7, image 1 de 1
    • Use your fingers or a spudger to detach the connector.
  8. IBM ThinkPad 560z Keyboard Cover Replacement: étape 8, image 1 de 2 IBM ThinkPad 560z Keyboard Cover Replacement: étape 8, image 2 de 2
    • Carefully lift and remove the keyboard.
Derek Driscoll
Membre depuis le 04/15/10
119 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 26-27, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 membres
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 19
Total : 1,814
