Aller au contenu principal
Pièces
  1. Flip the ThinkPad over so that it is upside down. Slide the highlighted tab to the left.
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Remove the two 5.3mm cover screws. Gently lift the cover containing the RAM.
    • Remove the two 5.3mm cover screws.
    • Gently lift the cover containing the RAM.
  3. Remove RAM module by pressing the two metal pieces outward with your thumbs.
    • Remove RAM module by pressing the two metal pieces outward with your thumbs.
  4. Lift the RAM module up and out, away from the yellow connector. Place the RAM module away from any magnets or static electricity prone areas.
    • Lift the RAM module up and out, away from the yellow connector.
    • Place the RAM module away from any magnets or static electricity prone areas.
Jessica
Membre depuis le 06/10/2010
162 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 4-44, Amido Fall 2010 Membre de l'équipe Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 membres
26 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,887
