Introduction
Use this guide to replace the RAM in your IBM ThinkPad T30
Ce dont vous avez besoin
Flip the ThinkPad upside down with the bottom facing you.
Slide the latch to the right into the unlock position.
While holding the latch in the unlock position, lift the battery out with your other hand.
Remove the 4 mm Phillips #0 screw located on the panel on the bottom right of the ThinkPad.
Lift up the cover and set it aside.
