Aller au contenu principal
IBM ThinkPad T41 Modem Replacement
Ce dont vous avez besoin
  1. IBM ThinkPad T41 Modem Replacement, Keyboard: étape 1, image 1 de 1
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
  2. IBM ThinkPad T41 Modem Replacement: étape 2, image 1 de 1
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
  3. IBM ThinkPad T41 Modem Replacement: étape 3, image 1 de 1
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
  4. IBM ThinkPad T41 Modem Replacement: étape 4, image 1 de 1
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
  5. IBM ThinkPad T41 Modem Replacement, Modem: étape 5, image 1 de 1
    • Remove the three screws holding down the modem in the upper left corner of the laptop.
  6. IBM ThinkPad T41 Modem Replacement: étape 6, image 1 de 1
    • Lift the modem up, unplugging it from the motherboard as you lift.
  7. IBM ThinkPad T41 Modem Replacement: étape 7, image 1 de 2 IBM ThinkPad T41 Modem Replacement: étape 7, image 2 de 2
    • Pull out the wire that connects the modem to the screen.
    • Unplug the other cable that attaches the modem to the motherboard
Marissa Blustein
Membre depuis le 04/16/10
501 Réputation
12 tutoriels rédigés
Équipe
Cal Poly, Team 7-8, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 membres
26 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 4,179
