Introduction
Removal/repair of the display
Ce dont vous avez besoin
Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
Flip the laptop over and open the screen to access the keyboard and trackpad.
Remove the plastic bezel along the edges, you may need to pry the areas circled with a spudger to remove the bezel.
Carefully unplug the display ribbon on the motherboard, then carefully lift the display free from the device.
6 autres ont terminé cette réparation.
2 commentaires
Very poor & sketchy guide! NO mention at all of how to handle the other wires involved in disconnecting the screen (lid) from the laptop base, eg: the wireless antenna connections and instructions like: "Unscrew the screws holding it down" are far too vague! holding WHAT down ffs!!!!
